Opinion regarding the turbo
Friends that turbo prefer for an Om605 pump 7.5 dieselmeken
- Borgwarner S200SXE S257
- Holset HX35 exhaust part 12cm
Thanks
I have HX35 on a bigger 3.0 OM603 and it's laggy and smoky... moving to a S200SX 51mm with the tight 0.83 AR housing to get this train rolling. When you look at the compressor map of the S200, it supports enough airflow and pressure ratio to run 30-35psi of boost without running off the map. Any more airflow and you can just add an S400 on-top which is my eventual plan.
