HE221W with OM617 exhaust manifold
Holset Turbo HE221W (5.5CM) - bought from EuroTrash Motorsports and was used on a OM617. Includes the following:
- Holset exhaust flange with V-band clamp and 90 deg section of 2.5" stainless pipe
- OM617 exhaust manifold, that has T3 adapter welded and bolted on then ceramic coated.
- (2) AN lines for oil feed and drain.
- Holset inlet elbow with reducer to 2" IC piping and V-band clamp
Turbo is clocked to work on OM617 engine with a custom bracket to hold wastegate
