STD Tuning Drivetrain Sprinter 6 speed swap
Om606STD
Gwagon OM606 STD
6
07-10-2020, 04:33 AM #1
With a 716.648 or higher manual what is the strongest setup (with part numbers). The Valeo Spinter SMF kit, Sachs BMW 765 pressure plate, and Sintered clutch disc are heavily favored but which part numbers?  Are the following compatible?
·        Valeo FW: 835013
·        Sachs 765 PP (BMW E34 M5) : 88 3082 999 765
·        BMW E34 Sinter clutch (6 puck):  Any preferred brand and/or part number?
My understanding is I need to have 1mm milled for the BMW disc to fit under the pressure plate, is this correct?  With this config I understand it should hold 500hp without a problem, is that correct?
Om606STD
·        Valeo FW: 835013
