FS: Vacuum Pump Delete Plate OM617 Vacuum Pump Block Off Plate, one solid piece of m
I do not believe I will need this now. One car is keeping the vacuum pump (China Blue) and another is getting rid of it (Red) but I have the factory MB block off plate which requires the plate to be milled down.
This was machined out of one solid block of aluminum. It is a robust piece, thick walled, and not prone to warping. I had this on my engine for a while and it worked out just fine. You do NOT need to do anything with the plate behind it or milling off the lobes like you would do if you had the factory block off plate. It bolts right on.
$150.00 shipped CONUS. You will need a new gasket. I cannot locate a spare. You use the same fasteners.
The forum won't let me post pictures. Snappies can be found here: http://www.peachparts.com/shopforum/merc...minum.html
