STD Tuning Engine Merge Collector 5-1
Merge Collector 5-1
Merge Collector 5-1
  • 1 Vote(s) - 1 Average
miguelrocha
02-22-2021, 02:10 PM #1
Can someone find me a template for A4 paper to make the right cuts to make a Merge 5-1? Thanks
I'm using 48.3 tube
miguelrocha
I'm using 48.3 tube
Simon B
02-22-2021, 02:34 PM #2
I doubt you will find such a thing, what you really need is a jig and a band saw.
Simon B
miguelrocha
02-22-2021, 06:42 PM #3
The band saw is missing: /
I only have an angle grinder
miguelrocha
Mallinman
03-01-2021, 02:51 PM #4
Just do what I did. Buy two lengths of pipe and just keep cutting till you get it right. There are online template calculators that you can put all ur details into and then print off the paper to wrap round the pipe to get the cuts. I used one and it got me just about there. Did save me quite a bit of time. 5-1 is so much harder than even tube numbers
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
