W203 with ASD Differential fitted
Hi guys,
for my w203 project I´m now looking for a LSD.
There are few options to buy from quaife or drexler in Germany, wich are all quite expensive.
Then I found this video, wich sais in the comments that its fitted with a w124 ASD differential.
https://www.youtube.com/watch?v=9FbKYfF94IA
I already changed on my previous w202 250TD a w124 ASD and the elbe clutch pack, now I wonder wich changes are neccesarry to fit it into a w203.
What i know so far, there where 210mm diff models in w124 and also 210mm models in the 203.
So seems like there are some similaritys.
I might buy a ASD 210mm model soon and check what is interchangable, but maybe someone can help with additional info before i spend the money?
I also just found out that drexler has some drawings on their homepage.
https://shop.drexler-motorsport.com/date...aSheet.pdf
Seems like the only dimensional differences between the types are in the length L3 and L4... And in the description they write its for w201-w202-w203.
So if i get the right parts together it should be possible to fit the whole ASD unit into the standart w203 diff?!
