STD Tuning Engine CC for low idle
CC for low idle
CC for low idle
dieseltorque
01-11-2023, 01:42 PM #1
Hello diesel guys!
I know it's a big secret, but I'll take a try,,,
I have a DIY pump PES 4M 60C 320 RS 185 with bigger elements, phasing is done, as well as balancing is no problem.
Rsf governor setup without modifications.
Question is how many cc we should set for low idle?
As far as I know its some where 8-12 cc at 350-370 rpm
 Thanks in advance!
This post was last modified: 01-12-2023, 02:16 AM by dieseltorque.
dieseltorque
Hello diesel guys!
 Thanks in advance!
Petar
7.5mm M pump
459
01-17-2023, 02:16 AM #2
Sadly very few people know and of those few even fewer are willing to share. The best info i've got comes from the STT turbo kit for OM617 instructions
http://www.superturbodiesel.com/std/atta...hp?aid=688
It says 7cc at 6.5mm rack travel at 350 pump rpm. OM60x might be slightly lower cc than 617 due to smaller displacement per cylinder
Petar
dieseltorque
01-23-2023, 12:19 AM #3
(01-17-2023, 02:16 AM)Petar Sadly very few people know and of those few even fewer are willing to share. The best info i've got comes from the STT turbo kit for OM617 instructions
ok, tnx for information!
 so we decided full load cc keep equal between cylinders and low idle we kept bit higher. We got approximate  8-9 cc low idle as there is small disorder between elements. So far engine works very good,,
dieseltorque
