STD Tuning Engine Could I remove the turbocharger from a turbocharged engine and use it as an NA engine
Rishiganasen
11-29-2024, 03:27 AM #1
Planning to replace the 602 2.5 na in my rhd W126 with an 662.925 from an rexton 2.9.i was planning to fit it together with the turbocharger but from what I see the turbo charger could interfer with steering box. So could if just fit the 602na intake and exhaust manifold on the 662 and just continue using the engine?
Rishiganasen
Niko
12-02-2024, 02:17 AM #2
If it has a mechanical pump, you're fine.
Niko
Rishiganasen
12-12-2024, 04:10 AM #3
(12-02-2024, 02:17 AM)Niko If it has a mechanical pump, you're fine.
Noted thanks for the info
Rishiganasen
