STD Tuning Engine Need help with OM606 ecu map locations with winols
Echo575
03-14-2025, 05:48 AM #1
Hey, I soldered 2 sockets into my ecu and tested that the car runs with the 2 stock chips in the plcc32 sockets. I took the program onto my pc with a t48 programmer and can put it into winols but I can't make sense of it. I guess I would need a xdf definition file but can't find one and don't know how to locate maps without it.
I saw map names on forums for drivers wish 3a000 but when I read with winols, it's empty on 3a000. I only have hex numbers before 3xxxx in winols and all after it are blank entries. The stock chips are HHH625 and LLL625 named and I have no idea what the difference is between them, reading the files in winols makes me think they are identical eproms?
Most of the data is in numbers like 2a000 but nothing exists in 3a000 but people say on the forums that there is data there?
What am I doing wrong? I really want to program the ecu myself and make adjustments when I fit a bigger turbo
Echo575
Echo575
03-14-2025, 10:02 AM #2
Ok, I got an answer from a tuner friend to this. You combine the L and H files when editing. He also told me that if I can't figure it out, he can make me a xdf definition
Echo575
