OM605 dyno
OM605 dyno
(11-28-2009, 07:32 PM)E300TSC Wow, very nice!Thanks. Im just Naturally-aspirated . Hpe i get that 500hp on fife sylinder what i aim for.
Looks like a bit of a dyno queen, why not put a VNT/VGT turbo on there? What did you do to the cylinder head. If you could get more of that power closer to 2400rpm that would be tits. What boost levels are you seeing at 2k,3k and 4k?
(12-02-2009, 05:00 PM)winmutt Looks like a bit of a dyno queen, why not put a VNT/VGT turbo on there? What did you do to the cylinder head. If you could get more of that power closer to 2400rpm that would be tits. What boost levels are you seeing at 2k,3k and 4k?Dyno queen or not. This car goes on the road just fine No vnt coming on this car, or any my cars.
(11-29-2009, 04:58 PM)jeemu(11-28-2009, 07:32 PM)E300TSC Wow, very nice!Thanks. Im just Naturally-aspirated . Hpe i get that 500hp on fife sylinder what i aim for.
Nice curves jeemu, and I have been following your video posts for some time now.
In addition, I really like the rpms you are able to turn with what looks like a modification to the timing device. What is the rpm limit? What rpm (if you can tell) does the injection pump stop advancing?
Thanks!
(12-02-2009, 06:02 PM)jeemu Now i installed main priority valve
(12-02-2009, 09:19 PM)ForcedInductionIts a valve that opens before turbo make boost. When intake is boost valve is closed.(12-02-2009, 06:02 PM)jeemu Now i installed main priority valve
I saw that video but I still don't understand its function.
(12-03-2009, 02:43 AM)jeemu Its a valve that opens before turbo make boost. When intake is boost valve is closed.
(12-04-2009, 03:19 PM)TymbrymiYou are 100% correct(12-03-2009, 02:43 AM)jeemu Its a valve that opens before turbo make boost. When intake is boost valve is closed.
Does it bypass the intercooler when the turbo isn't making any boost? That would allow the engine to flow better without boost, right?
Thanks for all the info you keep giving us!!
(12-04-2009, 03:23 PM)jeemu You are 100% correct
(12-05-2009, 01:50 PM)Tymbrymi(12-04-2009, 03:23 PM)jeemu You are 100% correct
Awesome! Thanks for the info! So I guess you've seen some benefit from it in your testing so far? That's very interesting since I didn't think the huge intercoolers you use would really pose that much of a restriction.
It is not the intercooler or charge piping that causes the restriction, but rather the inertia from the large diameter compressor and turbine wheels.
I've noticed this as well using a Holset HX40 using a gasser turbo gauge, and would see a bit of vacuum upon revving the engine. It is more pronounced when the engine/turbo is cold. I would imagine the benefit is even greater with a larger turbo than the HX40.
In addition, allowing the extra air into the engine, without any vaccum, will feed more exhaust products to the turbine wheel, decreasing the time for the turbo to spool, creating boost faster.
(12-05-2009, 02:37 PM)DervTuning It is not the intercooler or charge piping that causes the restriction, but rather the inertia from the large diameter compressor and turbine wheels.DervTuning is right. Big wheel Turbo spins "slowly" at low rpm, so engine have more air for breather valve and makes engine low end and turbo spooling better. This Master Power wheels are 65mm kompressor and 69mm turbine.
Nice looking engine! Is that a Piper Cross air filter on the priority valve?
(12-07-2009, 04:13 AM)CID ViciousThanks. We all have own opinions and that is good. If someone sees that a dyno gueen, thats ok. I dont loose my sleep(12-02-2009, 05:00 PM)winmutt Looks like a bit of a dyno queen, why not put a VNT/VGT turbo on there? What did you do to the cylinder head. If you could get more of that power closer to 2400rpm that would be tits. What boost levels are you seeing at 2k,3k and 4k?
I don't know if I'd call that a dyno queen. Still has 200lb-ft at about 2400 rpm, and how much do you need in cruise mode? Besides, take the turbo size down a notch, lose a little top end power and it'd be better for regular street duty, swap the turbos out for fun time, keep about 85% of the power but it's more usable for more mundane driving...I'll take 85% of that graph any day .
Yeah, I don't think it's a dyno queen, might be a little more of a 'four cylinder' type power curve instead of a V8 power curve minus the top end power...like a Honda, just with 600+ lb ft!
Jeemu, you're a Finnish MB diesel head who actually shares info with us crusty Americans...get crackin' on a 617 and you can be our Yoda .
Glad to see some Finns here on the US board. Suomi!
Check out the exhaust manifold/header - NICE.
On edit - here's the link: http://kuva1.kuvablogi.com/iso/img984033.jpg
Beers,
Matt - 1/4 Finn and dang proud of it.
(12-07-2009, 10:00 AM)jeemu Thanks. We all have own opinions and that is good. If someone sees that a dyno gueen, thats ok. I dont loose my sleepIts not like I haven't stopped drooling over it . I would just be interested to see what a big frame VNT would do for it.
(12-07-2009, 01:18 PM)HoleshotHolset Glad to see some Finns here on the US board. Suomi!Hello. Thanks. That manifold is my first what i did on Mersu.
Beers,
(12-07-2009, 01:48 PM)winmuttDont drool yor laptop goes ruined(12-07-2009, 10:00 AM)jeemu Thanks. We all have own opinions and that is good. If someone sees that a dyno gueen, thats ok. I dont loose my sleepIts not like I haven't stopped drooling over it . I would just be interested to see what a big frame VNT would do for it.
Beers,
Jeemu, you need to rock that thing for awhile in that green urethane primer...it'd look tits with those wheels and Plasti-dipped trim, and you could paint it and peel the plasti-dip off later if you wanted to.
Assuming the whole car is getting repainted, of course, a green nose on a different colored body would look pretty retarded. Then again, when you stomp someone's ass at a stoplight, they'd have gotten beaten by 'that retarded looking Mercedes'
[/quote]
[/quote]
This thread is about Jeemu's car, but I intend to do just that. I have a GT45R VGT just about ready to fit to an OM606. I will let everyone know how well it works on the engine that will be fitted with the 7.5mm diameter M75 Floyd elements.
Back to Jeemu's car ! I am loving these clamps!
http://kuvablogi.com/nayta/2292038
http://kuvablogi.com/nayta/2245329/
[/quote]
[/quote]DervTuning has awesome project by the way what engine that 201 chassis has been? My w124 weight 1350kg =2975lbs
Those HDi clamps are wery good stuff.
Today i do injection adsustment what increases when boost increas.
http://www.youtube.com/watch?v=uDf3Rob6Pr4
(12-09-2009, 02:57 PM)jeemu DervTuning has awesome project by the way what engine that 201 chassis has been? My w124 weight 1350kg =2975lbs
(12-12-2009, 02:45 PM)jeemu Today i do injection adsustment what increases when boost increas.
The engine that is in the w201 chassis is the 2.3-16 valver, which will be pulled in lieu of the om606. I will be sure to weigh the car when the swap is complete.
(12-14-2009, 06:29 PM)TymbrymiHello. Yes that is normal wastegate actuator. Not smoke that much as the Mb original "morkooli"(12-12-2009, 02:45 PM)jeemu Today i do injection adsustment what increases when boost increas.
Very cool!! That is just a standard pressure wastegate actuator correct? I think you're the first person I've ever seen implement the ALDA functionality on an NA pump.
jeemu, on a random note, would you explain what you did to the timing device? It looks like you removed some metal from the stop peg. Did you do anything else? Also, what do you set your timing at?
Thanks!!
(12-15-2009, 10:51 AM)Tymbrymi jeemu, on a random note, would you explain what you did to the timing device? It looks like you removed some metal from the stop peg. Did you do anything else? Also, what do you set your timing at?Hello. Just took material off. More advance on higher revs. Dont do anything else. Timing in now 16degrees advanse.
Thanks!!
Thanks!!
(12-15-2009, 12:16 PM)jeemu Hello. Just took material off. More advance on higher revs. Dont do anything else. Timing in now 16 degrees advanse.
(12-15-2009, 12:35 PM)TymbrymiThats why the forums are. Share informations(12-15-2009, 12:16 PM)jeemu Hello. Just took material off. More advance on higher revs. Dont do anything else. Timing in now 16 degrees advanse.
Awesome! Thanks again for the info.
(12-14-2009, 06:29 PM)Tymbrymi I think you're the first person I've ever seen implement the ALDA functionality on an NA pump.Hmm...looks kinda familiar compared to mine
(12-15-2009, 05:36 PM)muurisHa. Yes it does my friend . In my case that is not solid in the stop axle. Stop axle is free to move down when you turn engine off.(12-14-2009, 06:29 PM)Tymbrymi I think you're the first person I've ever seen implement the ALDA functionality on an NA pump.Hmm...looks kinda familiar compared to mine
Don't know how it works if made on original turbo pump (like jeemu's), but this was NA pump so little modification had to be made inside the pump. The lever in that stop-axle had to be made independet of axle's position, so the vacuum actuator on the top of the pump could stop the engine (without this mod, you can't stop the engine if actuator is directly connected to stop lever!). Then another lever was welded to the axle, so the ALDA actuator can limit fueling. So both the vacuum-operated stop- and ALDA -actuators can limit fueling independent of each other. Too bad I didn't take any pictures..
(12-15-2009, 05:36 PM)muuris Hmm...looks kinda familiar compared to mine
(12-16-2009, 11:09 AM)Tymbrymi(12-15-2009, 05:36 PM)muuris Hmm...looks kinda familiar compared to mine
Whoops!
Thanks for the excellent explanation of how you did your modification. When those of us on this side of the pond get to modifying things to your level that description will come in handy!
Whoops!
Just want to show you the latest ALDA mÿna is now mounting to the pump.
Hope this will keep the smoke under control.
Hope to mount it soon.
By the way this is also going on an OM606 :-)
How much does KKD sell their 603 manifold for? i cant read their website i don't speak the language. I was going to build my own but if it's the right price i will just buy it. Also do you know if it will fit on a 603 that is in a 190e series?
thanks for the help
Nathan
Beers,
[/quote]
Now i bought manifold fron KKDmotorsport. http://kkdmotorsport.kuvat.fi/kuvat/pakosarjoja/
om605 http://kkdmotorsport.kuvat.fi/kuvat/pako....5syl+.JPG
There is new photos on my car, if someone is interest
http://kuvablogi.com/blog/6520/16/
(12-20-2009, 12:53 PM)winequip_td How much does KKD sell their 603 manifold for?
Excellent info - thanks for sharing.
If timing is advanced 16° at higher RPM - what is your static timing at idle? In your chassis dyno video, it sounds like a LOT of timing - but IDI's tend to sound different than DI diesels.
At what RPM does the timing device start to add more timing?
I know the OM606 in my car needs more timing - at anything above about 1200 RPM - it sounds like a gasser. Checking/adjusting the timing is on the to-do list.
Beers,
Matt
(12-22-2009, 06:37 AM)jeemu Timing is 16degrees advance. Dont know what it is in high rpm.
This mod increase advans on high rpm
the mod that myna does to the stop lever doe anyone know what exactly that does? Does it add more fuel or is it something to do with timing?
(12-25-2009, 09:57 PM)winequip_td the mod that myna does to the stop lever doe anyone know what exactly that does? Does it add more fuel or is it something to do with timing?
It does just the same thing as originally (reduces fueling). Now it just doesn't reduce fueling enough to stall the engine, but to lessen smoking when not on boost (ALDA function, but with larger travel range). Now that the pump has been modified, the maximum fueling (stop lever all the way up) is 4 to 5 times the original, but the non-boost fueling has to be remained close to original. This is when stop lever is about 4/5 down of the travel.
(12-20-2009, 08:24 PM)brynton I was quoted 500 euros for the om605 plus another 50 shipping>
They do look really nice though
(01-09-2010, 08:09 PM)jeemu
(01-12-2010, 12:10 PM)TymbrymiYes i took. Those will but back when chambers is cleaned good.(01-09-2010, 08:09 PM)jeemu
Did you take the prechamber pins out on purpose? Do you run them like that in the engine?
Hopefully he can fix your head!!
