Stupid question - VNT-turbo install - M21D24(BMW)
Hello guys.
I've bought an VNT-turbo from 220cdi W211, since my original turbo is singing on its last phrase.
I have questions about the steering of VNT.
My question is stupid, but I want to give it a try:
-What happens if I weld the "WG-rod", or pressure steering rod, in locked position, or lock the vacuum intake-line? Will it be driveable? it will propably give very high turbo pressure and the vnt-system want be able to be controlled, but still, will it work?!
You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed.
(03-13-2012, 09:02 AM)Simpler=Better You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed.
Get a second gauge for backpressure if you're going to do that.
(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that.
(03-13-2012, 09:19 AM)Diesel-Wiking(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that.
You think it will be a problem? or just to controll the backpressure?
(03-13-2012, 12:29 PM)Alastair E(03-13-2012, 09:19 AM)Diesel-Wiking(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that.
It could well cause a problem.
Too much exhaust back-pressure can completely bog-down the engine, so it will make less power than a N/A engine and make LOTS of smoke!
The trick is to get the boost high and the back-pressure as low as possible,--Not easy!....
For what it's worth, when I first ran my 2056V I had the actuator in backwards...The turbo spooled instantly , but wouldn't let me go beyond 2,000repm.
