feed pump question
feed pump question
hello guys,i have a std project going on an i have a little quesiton for u.im planning to swap a modified 606.962 in my e230 petrol car.so i wondered if i could use the fuel pump whose already in my petrol car and regulate down the pressure and use it as a feed pump for my dieselmeken pump?
(04-01-2012, 12:22 PM)w210tdt ok,thanx!the feed pump on the ip will do the job then,also on high performance engines.
(04-03-2012, 01:27 AM)EDH_Performance(04-01-2012, 12:22 PM)w210tdt ok,thanx!the feed pump on the ip will do the job then,also on high performance engines.
NOT on big elements like 7.5mm! My pump ran out on diesel at around 3000rpm with 7.5mm elements, and stock ip feedpump! So i used a gasser pump (from a volvo 740turbo), and regulated it to 3 bars feeding pressure
(04-03-2012, 01:38 AM)w210tdtSounds good(04-03-2012, 01:27 AM)EDH_Performance(04-01-2012, 12:22 PM)w210tdt ok,thanx!the feed pump on the ip will do the job then,also on high performance engines.
thanx for the info edh!my plan is to do the same as you!
nes,akershus..my pump is at dieselmeken waiting for version 2 elements,but now his got some issues with them so i will go for the version1.so i think i will get the pump back soon.then the project begins!!plan is get the car through the eu-controle in first of may before i put in the engine
(04-03-2012, 02:52 AM)w210tdt nes,akershus..my pump is at dieselmeken waiting for version 2 elements,but now his got some issues with them so i will go for the version1.so i think i will get the pump back soon.then the project begins!!plan is get the car through the eu-controle in first of may before i put in the engine
When you got IP that can make over 150cc and you car can burn all that you notice broplems, but if you not notice any, then you got to do some tune your car
Good and cheap trancfer pump is Holley HP150, thar regulator what come belong, just throw away.
(04-03-2012, 03:20 PM)jeemu When you got IP that can make over 150cc and you car can burn all that you notice broplems, but if you not notice any, then you got to do some tune your car
(04-03-2012, 03:20 PM)jeemu When you got IP that can make over 150cc and you car can burn all that you notice proplems, but if you not notice any, then you got to do some tune your car
Good and cheap transfer pump is Holley HP150, that regulator what come belong, just throw away.
(04-04-2012, 02:07 AM)erling66Last setup i had 1bar transfer pressure.(04-03-2012, 03:20 PM)jeemu When you got IP that can make over 150cc and you car can burn all that you notice proplems, but if you not notice any, then you got to do some tune your car
What Pressure is good from the transfer pump? I read that 22-25psi would be fine? Jeemu how much do you have?
