STD Tuning Engine Electric Fuel pump
Electric Fuel pump
Electric Fuel pump
Pages (3): Previous 1 2 3
tomnik
10-03-2010, 05:37 AM #101
max. pressure not specified.
Tom
.pdf
07-145_ck_fuelpump_ovflowvalve.pdf
tomnik
Tom
.pdf
10-03-2010, 06:14 AM #102
(10-03-2010, 12:50 AM)muuris It doesn't have banjos like the old ones, but crappy plastic pieces with o-rings and a holy spirit holding the things together.
G@s engines make over 60psi with those types of connections.
muuris
OM605
318
10-03-2010, 10:03 AM #103
Thanks tomnik, that's great! Seems pressures are a bit on the low side on mine, although I didn't test whilst in neutral, but while driving.
(10-03-2010, 06:14 AM)ForcedInduction G@s engines make over 60psi with those types of connections.
And on many OM605/6 the filter housings have been changed to old style ones due to leaking with under 15psi. I changed all the o-rings in mine but it still wasn't very convincing.
Anyone experimented how a g@sser high pressure fuel pump works with diesel in the winter?
This post was last modified: 10-03-2010, 10:05 AM by muuris.
muuris
300D50
Graphite Moderator, ala RBMK
10-03-2010, 01:33 PM #104
I'll be running an OEM Mitsubishi pump in my truck, it's already in the tank so why not use it? I'll be using the oem fpr as well, so we shall see...
300D50
10-03-2010, 02:03 PM #105
(10-03-2010, 10:03 AM)muuris Thanks tomnik, that's great! Seems pressures are a bit on the low side on mine, although I didn't test whilst in neutral, but while driving.
It has not been below 70 degrees for me to test with...
10-03-2010, 03:09 PM #106
(10-03-2010, 02:03 PM)Captain America It has not been below 70 degrees for me to test with...
Put them in the freezer.
10-03-2010, 04:39 PM #107
I don't have access to a freezer where the fuel pump test stand is at my work. I doubt the girls inside would like a bucket of diesel in the fridge... haha
98taco3
10-04-2010, 03:18 AM #108
anyone ever messed with an airdog system? Ive got one on my pickup and when i first installed it the pressure was set to 40psi! Seems like it would flow plenty of fuel and better filtration to boot...
98taco3
10-05-2010, 06:33 AM #109
(10-04-2010, 03:18 AM)98taco3 anyone ever messed with an airdog system?
There is no benefit besides the electric pump. The stock filter system already deaerates the fuel and adding a water separator would cost about $15+filter.
http://www.superturbodiesel.com/std/chea...-1648.html
Electric pumps used on Powerstrokes can be had for around $75-100.
This post was last modified: 10-05-2010, 06:34 AM by ForcedInduction.
mr_manny
Diesel Offroad Club
91
11-12-2010, 12:32 AM #110
Could you guys recommend a good in-line unit for my toyota fj40/om617 conversion?
I would like to utilize the stock tank...thinking an inline pump and regulator is the answer.
The fuel system is one of the items that need to be addressed, before I can drive my fj40 home Sad
mr_manny
mr_manny
Diesel Offroad Club
91
11-13-2010, 09:15 AM #111
I met a guy yesterday who installed an om617 into an 83 jeep scrambler.
When I asked him about which lift pump he was running, he said that he wasn't running one...
I mentioned that the 300D came with an in-tank pump from the factory.
He has been running his without one for over a year, with apparently no adverse affects.
thought I would share the video of a happy jeep owner Smile
YouTube - om617 in an 83 jeep scrambler
mr_manny
11-13-2010, 09:56 AM #112
(11-13-2010, 09:15 AM)mr_manny I mentioned that the 300D came with an in-tank pump from the factory.
No there isn't. He is probably just using the g@sser's in-tank pump.
mr_manny
Diesel Offroad Club
91
11-13-2010, 10:46 AM #113
(11-13-2010, 09:56 AM)ForcedInduction
sorry, but I was under the impression that in-tank pumps were factory Tongue
thanks for the education Smile
mr_manny
ben2go
Diesel Dumby
129
11-15-2010, 06:52 PM #114
The 83 Jeep that mr_manny was speaking of doesn't have an in tank pump stock.They were still using block mounted mechanical pumps,unless it was converted to FI before going diesel.
ben2go
rdirtycar
flash gordon
145
11-18-2010, 12:59 PM #115
Does anyone know how many GPH the MW pump can flow back through the return outlet at idle? I'm worried a big electric fuel pump will make overpressurization if the fuel can't get through the IP quick enough. I guess since the inlet is the same size as the outlet, overpressurization can only happen in the line before the pump so it doesn't matter. Am I wrong here?
This post was last modified: 11-18-2010, 05:04 PM by rdirtycar.
rdirtycar
muuris
OM605
318
11-18-2010, 05:04 PM #116
I tested with a g@sser pump, no pressure regulators other than the banjo. M-pump. Max pressure I got in any situation was a bit less than 30psi (before filter).
This post was last modified: 11-18-2010, 05:04 PM by muuris.
muuris
rdirtycar
flash gordon
145
11-18-2010, 09:17 PM #117
(11-18-2010, 05:04 PM)muuris I tested with a g@sser pump, no pressure regulators other than the banjo. M-pump. Max pressure I got in any situation was a bit less than 30psi (before filter).
do you have 30 psi going uphill full throttle?
rdirtycar
mr_manny
Diesel Offroad Club
91
11-18-2010, 10:29 PM #118
(11-15-2010, 06:52 PM)ben2go The 83 Jeep that mr_manny was speaking of doesn't have an in tank pump stock.They were still using block mounted mechanical pumps,unless it was converted to FI before going diesel.
correct, 83 jeep/om617 does not have an electric pump.
mr_manny
muuris
OM605
318
11-19-2010, 04:54 AM #119
(11-18-2010, 09:17 PM)rdirtycar do you have 30 psi going uphill full throttle?
No. As it was a basic gasser high pressure pump, it wasn't enough for tuned M pump. When floored, pressure was less than 10psi at under 3500. Very low at 6000.
Now I have a different pump, have to re-install the pressure gauge to get the new readings.
muuris
rdirtycar
flash gordon
145
11-19-2010, 12:27 PM #120
It's cool talking with people so far away. I'm going to get rid of the banjos and use straight metric to AN adapters in and out of the IP. Should be plenty for the 45 GPH or so at 30psi I think I have.
rdirtycar
Silberpfeil
Slowly Sideways
85
12-03-2010, 04:45 AM #121
(11-19-2010, 12:27 PM)rdirtycar It's cool talking with people so far away. I'm going to get rid of the banjos and use straight metric to AN adapters in and out of the IP. Should be plenty for the 45 GPH or so at 30psi I think I have.
I'd like to see the pictures when you're done and hear what you think of the mod.
Silberpfeil
rdirtycar
flash gordon
145
12-03-2010, 11:15 AM #122
I just got a Ford escape real cheap so the Benz is going up on blocks for the winter. It will give me a chance to do some real work and not have to drive the thing the next day for work.
rdirtycar
12-03-2010, 05:06 PM #123
Yes hurry the hell up with that! I wanna see and know what fittings you ended up using
X Double Dot
04-27-2017, 10:18 PM #124
7 years...this is a record revival attempt for me.  Did anyone ever try running with a gas fuel injection electric intank pump (~typically rated around 50psi for the FI gas application) on their 606/5?  Curious to know if the regulator system on the mercedes could handle it, and if so, did you get rid of the on engine mercedes lift pump?  Additionally I was curious if anyone knew how the gas pump did during the winter months with the thicker diesel fuel.
asking as I'm putting a 606.692 in a 1994 Toyota truck that currently has a ~50psi intank fuel pump for a gas FI engine.  ideally i'd just be hooking up lines and not having to drop the fuel tank to remove the intank pump + buy new components.
This post was last modified: 04-27-2017, 10:22 PM by X Double Dot.
X Double Dot
04-28-2017, 12:46 AM #125
just add a 1.5 bar relief valve back to tank, pre filter. it will work for sure.
04-29-2017, 12:11 PM #126
Impressive ancient post excavation lol.
I have the 1.5 bar pressure release outlet banjo barrote mentioned, instead of the stock 0.5 bar one, dam sure works, every fuel fitting started leaking and I can't push in the priming button on my filter housing now (Bosch/CAV). That's with the standard lift pump, with stiffer spring & rebuild with Viton O-rings.
I got a Bosch 044 in the post and the internet people and my mates say the 1.5 bar banjo mentioned above will not flow enough to reduce the 4-5 bar from the 044 down to 1.5 bar, as this banjo bolt only has about a 4mm hole in the middle which the spring loaded ball acts upon.
So I bought one of those eBay rising rate fuel pressure regulators which I intend to fit downstream of the IP, and adjust down the IP gallery pressure to 1.5 bar reference pressure. ( I am copying 'erx' build thread on this forum's design, see his thread.
Ideally I would gauge pressure the IP inlet feed fitting and confirm the 1.5 bar banjo does not bleed sufficient fuel to regulate the 044 but I've already bought the FPR..
The above post possibly doesn't help you at at all but may make for interesting reading if nothing else..
Well I suppose to summarise, fit an eBay FPR and you can use the stock vehicles in tank pump..
Beers, HH
This post was last modified: 04-29-2017, 12:13 PM by Hario'.
Beers, HH
X Double Dot
05-04-2017, 07:46 AM #127
thanks for the replies guys.  i'm looking at this style http://fuelab.com/products/performance/f...regulator/.  it's only up to 0.8 bar, but my guess is that is better than the vacuum the lift pump is currently working with.  that said I don't claim to be an expert on these fuel systems.  Is there a reason people have mentioned this 1.5 bar? is that for people going with big turbos/pumps?
X Double Dot
05-04-2017, 09:47 AM #128
That is only necessary if u have a superpump.
With stock pumps is only placebo efect....
X Double Dot
05-04-2017, 04:45 PM #129
(05-04-2017, 09:47 AM)barrote That is only necessary if u have a superpump.
haha good to know.  thanks for the info,
X Double Dot
tjts1
05-13-2017, 09:56 AM #130
The accelerometer app on my phone respectfully disagrees. I'm using a delphi FD0040 at the tank.
[Image: 208104.png]
tjts1
[Image: 208104.png]
