STD Tuning Engine 83 300D IP swap
83 300D IP swap
83 300D IP swap
BRABUS
11-20-2010, 11:17 AM #1
As topic says.
Gonna remove my M IP becuase its gonna be rebuilt, since i need the car i have a MW IP ready to mount.
Whats there to think about performing this swap?
Im pretty green on this diesel engines Big Grin
Should i set the crank on 24 degrees before TDC?
Then just turn the camshaft of the pump if necessary until the markings are aligned on both pump and camshaft?
After this it should be around 24 degrees? after this i will start the timing procedure?
Best regards
BRABUS
As topic says.
Best regards
DrewGerhan
101
11-20-2010, 09:29 PM #2
Make sure both cam lobes are pointing up, compression stroke. Sounds bout right otherwise.
DrewGerhan
BRABUS
11-21-2010, 04:36 AM #3
Should both cam lobes pointing up, when the engine is 24btdc at crankshaft? right?
BRABUS
11-21-2010, 06:55 AM #4
You will need the correct linkage setup and injection lines, they are not compatible between pumps.
This post was last modified: 11-21-2010, 06:55 AM by ForcedInduction.
BRABUS
11-21-2010, 07:58 AM #5
Forced - i have the innjection lines. But i think i threw away the throttle linkage. How diffrent is this?
BRABUS
