STD Other Projects Ford Transit 1980 with a supercharged Mercedes 606
  • 4 Vote(s) - 4 Average
Pages (2): Previous 1 2
03-21-2013, 08:42 AM #51
man this is coming along splendidly. I love the shifter solution. I think for my van, ill be installing a center mount parking brake as well, I hate the pedal parking brake.
I gotta catch up with you. Big Grin
x3 on that green. Reminds me of a mopar
I think you should do the same flat black style racing stripe with the diesel info kinda similar! Smile
erling66
SuperDieselVan
294
04-13-2013, 09:06 AM #52
I have just started the job to remove all paint and rustSmile But behind the fenders there are some type of plastic like rust protection that are very difficult to remove. Sandblasting doesn't help. Does anyone have some advise? maybe some liquid that will melt it?
[Image: P4130009_zps1b51a6c0.jpg]
HuhCoolTongue
erling66
HuhCoolTongue
04-13-2013, 09:16 AM #53
(04-13-2013, 09:06 AM)erling66 I have just started the job to remove all paint and rustSmile But behind the fenders there are some type of plastic like rust protection that are very difficult to remove. Sandblasting doesn't help. Does anyone have some advise? maybe some liquid that will melt it?
Id get a chemical mask and try a heat gun, see if it loosens it up enough to scrape off.
Id suggest paint remover, but my experience has been that paint remover is really good for 1-3 layers of paint at a time, and some kind of thick undercoating it would probably take longer than just wire wheeling it all off.
This post was last modified: 04-13-2013, 09:17 AM by JB3.
HaavardPYA
04-17-2013, 04:45 PM #54
The white thick stuff there is a bit tricky to get of. Cleaned may Granada for that stuff, and it took a while. Paint remover does not help. Little bit easyer with heat. Best is to sharpen up some flat metal about 3cm wide and weld it to a screwdriver and use it as a scrape. Make sure its stiff enough.
I would advise you to only remove it around where the rust is and let the rest be. Weld the rust and put new "bodyskydd" over there again. Its not dangerous to paint over it.
HaavardPYA
Ksteen2
04-26-2013, 01:59 AM #55
how's the mighty Ford doing?
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
erling66
SuperDieselVan
294
05-16-2013, 09:47 AM #56
I have started to remove the rust and sand blast it. As usual you discover 5 times more rust than you thought(or hoped for)Confused
Here is a hole I found in the front corner:
[Image: P4130011_zps6b728d77.jpg]
and now it is goneSmile
[Image: P5160015_zpsed168e8d.jpg]
The welding is not perfect but if you want to do that, it will take foreverDodgy
HuhCoolTongue
erling66
HuhCoolTongue
05-16-2013, 12:07 PM #57
Looks great to me Smile
erling66
SuperDieselVan
294
05-18-2013, 11:39 AM #58
Finally some real progressSmile The engine bay has been primed with 2 k epoxy primer. First I removed all the nasty putty Ford used and sandblasted everything, then welded the rust holes. Sandblasted the welded spots and then it was time for primer.
[Image: P5180004_zps626f4692.jpg][Image: P5180005_zps5666ef6a.jpg]
HuhCoolTongue
erling66
HuhCoolTongue
mantahead
05-18-2013, 02:29 PM #59
looking good Erling.
mantahead
Ksteen2
05-21-2013, 03:12 AM #60
nice, it will soon be done then? Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
10-24-2013, 11:58 AM #61
any recent updates?
question on the parking brake, was that original to the van center mounted like that?
Looking at that again, I love that solution with the shifter above the assembly like that.
I wish I could do the same with my arrangement, but most of the mechanism is below the floor on mine.
any recent updates?
erling66
SuperDieselVan
294
10-25-2013, 01:52 AM #62
(10-24-2013, 11:58 AM)JB3 any recent updates?
Hi
No updateConfused I have been working on a daily driver project with a 604 turbo, It is not such a big job so hopefully it will be finished in a month and then I can work on the Transit againSmile
The Parking brake is original, it is a nice arrangement, you can even lock the rear wheels whit it when drivingBig Grin
HuhCoolTongue
erling66
Hi
HuhCoolTongue
Gearbound
In need of a OM606.96x
172
01-10-2014, 06:52 AM #63
Any more updates on the mean green machine?
Gearbound
erling66
SuperDieselVan
294
01-10-2014, 10:37 AM #64
(01-10-2014, 06:52 AM)Gearbound Any more updates on the mean green machine?
Hi
Well I bought another Green Ford (taunus) this summer and decided to put a OM604 in it with a big turbo, so the Transit has been on hold for a while. I will make a thread for the new project soon
HuhCoolTongue
erling66
Hi
HuhCoolTongue
Sotvisp
01-11-2014, 10:27 AM #65
How does the car runs tru the car inspect system (bilprovning på Svenska ) is it easier to fix in Norway ??
Just curious ..
Diesel Power
Sotvisp
Just curious ..
Diesel Power
erling66
SuperDieselVan
294
01-11-2014, 02:55 PM #66
(01-11-2014, 10:27 AM)Sotvisp How does the car runs tru the car inspect system (bilprovning på Svenska ) is it easier to fix in Norway ??
Just curious ..
I am curious tooTongue but everything is possible (but not easy) if you really want it to pass. A friend of mine has a VW transporter with a 1200hp twin turbo V8 Chevy that passed the inspection.
HuhCoolTongue
erling66
Just curious ..
HuhCoolTongue
Ksteen2
10-30-2014, 03:47 PM #67
the norwegian car inspection (vegvesen) is verry strict.. they would not aprove a OM606 in my W123 :/
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
