STD Maintenance General Hard starting 603
Hard starting 603
Hard starting 603
George3soccer
09-21-2012, 07:48 AM #1
Hey guys been having trouble starting in the mornings.
Motor cranks right over and starts right away after two glow plug turn overs. Glow plug light come right on.
Not sure what model glow plugs are in there right now.
Once started the motor seems like it doesn't fire on all cylinders and sometimes will stall after its started until I give it a little throttle to get it running at a higher rpm.
I have a video I it hiccuping with a hard start and smoking.
The smoke is a little blueish grayish. Not much black at all
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
aaa
09-21-2012, 08:06 AM #2
You should not need two glow plug turn overs.
Anyways, I would check compression and look suspiciously at the delivery valve o-rings. Then I would change the glowplugs. You can also test the plugs with a multimeter at the harness, it would detect obvious failures.
aaa
George3soccer
09-22-2012, 06:08 AM #3
Well I have been doing two. Most likely if I did one I bet it would fire right up. I don't want it not start or just crank so I have been doing two.
Compression test I will get back to you on that. Need to get a diesel tester, do not have one at the moment.
O-rings should I be looking for sweating right by the collar. Anything different.
Glow plugs I had a feeling I was going to have to upgrade. Is there any type I should be sticking with. I hear Bosch are still king. Monarks are crap still.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
83300d
09-26-2012, 10:26 PM #4
I had almost the exact same thing happen with my 617 and once I swapped out my glow plugs it would fire right away.
Had read that alot of the WVO folks had installed a switch in place of the glow plug relay, to help compensate for the time needed to warm up the oils, so I tried that and it works wonders on the times that it sputters and stalls.
But that could an indicator of something else - just giving you my two bits.
83300d
09-27-2012, 10:48 AM #5
Try waiting 10 seconds after the glow plug light turns off before starting. The glow plugs stay on longer than the light on my car 87 300sdl and that helps it a bunch.
