STD Tuning Engine Air line size question: turbo-IC-manifold
kotka
10-10-2012, 12:26 PM #1
hi,
I continue my project to "merry" om606A, mechanic pump with Tom's elements, GT28RS, customized IC and manifolds on my g-vagon.
[Image: i-82.jpg]
here the first cut of the manifold for your fun Big Grin but more to follow
so the question is:
a) the compressor output is 51mm
b) IC i plan put has 76mm in-out pattern
what line's (turbo-IC-manifold) diameter would you recommend?
i'm thinking of 76 or 63mm
76 would give more lag i think as the lines volumes is 21% larger then 63 ones. so more time to make sound pressure in there.
any ideas?
kotka
hi,
[Image: i-82.jpg]
so the question is:
any ideas?
10-10-2012, 01:01 PM #2
I've always believed that bigger is better so long as it fits under the hood. Don't know the exact effect on spool times, but it will probably be negligible (half a second? don't know)
10-10-2012, 06:40 PM #3
I'm not trying to rain on your parade or downgrade your work in anyway, but header pipes are all suppose to be the same length.
Other than that sounds like a bada** project! Smile
And i dont know about spool time, but ive been told by many that the bigger the piping after the turbo, the better.
kotka
10-10-2012, 10:39 PM #4
Same length of pipes helps get max output of the tubular manifold at paticular rpms. The diff length defenitelly reduces max "effectiveness" but smooth the torque pattern. In my case the smooth and extended high torque pattern is the key - it's a offroader Smile
It would be nice to make all pipes equal but g-vagon hood doesnt allow for this and.... this is not a racer Wink
Btw - what makes bigger line better?
This post was last modified: 10-10-2012, 11:15 PM by kotka.
kotka
10-11-2012, 07:23 AM #5
You can always make the pipes .5m long and stick the turbo up above the hood Big Grin
10-12-2012, 10:19 PM #6
(10-10-2012, 10:39 PM)kotka Same length of pipes helps get max output of the tubular manifold at paticular rpms. The diff length defenitelly reduces max "effectiveness" but smooth the torque pattern. In my case the smooth and extended high torque pattern is the key - it's a offroader Smile
I figured you knew more about it than i did, i was just throwin my 2 cents in Tongue The header looks pretty sweet!
