IP numbers...what do they mean?
Ive read a good few threads on here where they refer to how much fuel a pump can deliver:
standard 606 n/a pump is supposed to delivery 60cc,
while ive read about pumps with larger elements 7.5 ect giving anything from 120 to 200+ cc's
Is this at a max rpm, most of dieselmekens videos show 3000 rpm pump speed?
Or has it more to do with rack travel?
Or somthing else?
(01-31-2013, 09:37 AM)aaa The pump operates at half engine rpm.
(01-31-2013, 11:00 AM)Volker407 It also has to do with how much fuel you want to "squeeze" out of the element.
The maximum quantity an element can deliver is not necessarily a well usable quantity.
Gruß
Volker
Gruß
Volker
I believe that larger elements can be 'detuned' by playing with the pump internals, and the addition of an ALDA (whether stock or aftermarket).
The pump guys will have a better explanation, however.
