STD Other Pics and Videos blacksmokeracing new car, pump element seized.
mantahead
04-18-2013, 04:38 PM #1
mantahead
04-18-2013, 04:43 PM #2
Yeah I saw Sad
Yeah I saw Sad
HaavardPYA
04-21-2013, 05:59 AM #3
runs 3,9bar and only gets 500whp...
HaavardPYA
04-21-2013, 05:52 PM #4
Running too small of injectors will sieze pump elements up all day long.
I just can't get over the supercharger sound. It is like scraping nails on a chalkboard to me!
04-22-2013, 07:38 AM #5
(04-21-2013, 05:52 PM)MFSuper90 Running too small of injectors will sieze pump elements up all day long.
Whenever I hear a SC whine my first though is that their diff is dry...then I snap out of it when I realize it's coming from the front
04-22-2013, 09:34 AM #6
I always thought it sounds like a bad ford power steering pump
mantahead
04-22-2013, 09:56 AM #7
strange numbers and no graph.
This post was last modified: 04-22-2013, 09:58 AM by mantahead.
mantahead
04-22-2013, 10:31 AM #8
It's pretty obvious to me that the problem is the chassis. If it was still in a W123 it would be going strong :p
HaavardPYA
04-22-2013, 12:38 PM #9
What do you mean by "sieze pump elements up"?
This post was last modified: 04-22-2013, 12:47 PM by HaavardPYA.
HaavardPYA
04-22-2013, 01:27 PM #10
I'm guessing that with small injectors and large elements, you're trying to push more fuel than the injectors can flow, causing high pressures in the elements/lines, essentially locking them in place and causing a jam.
04-22-2013, 02:22 PM #11
(04-22-2013, 01:27 PM)Simpler=Better I'm guessing that with small injectors and large elements, you're trying to push more fuel than the injectors can flow, causing high pressures in the elements/lines, essentially locking them in place and causing a jam.
Exactly. Puts too much pressure on the elements. My neighbor kept sticking plungers in his pulling tractor on Scheid built pumps. He kept sending them back thinking the pumps were junk (not saying they aren't anyhow)
Put bigger injectors in it and solved his problem.
HaavardPYA
04-24-2013, 04:23 PM #12
Aha. I seeSmile
HaavardPYA
Aha. I seeSmile
w123love
Stockish
354
04-24-2013, 04:38 PM #13
Ended up they kept finding aluminum bits in the fuel system, which seized two pumps. They added a couple more filters and new lines in the past week. Apparently things are going smoothly now.
The VEGEWGN
w123love
The VEGEWGN
Bangaway
606 Turbo > Porsche Turbo
129
04-25-2013, 12:50 PM #14
I like the w123 more.
Bangaway
04-29-2013, 09:37 PM #15
I agree with Bangaway
HaavardPYA
04-30-2013, 05:06 PM #16
Me too! But i imagine the w203 is a better car for drifting in his class.. even though there where not much of a 123 car left on that car.
HaavardPYA
