STD Other Projects OM 602 G Mercedes build for off-road racing
Pages (2): Previous 1 2
07-09-2013, 03:52 PM #51
(07-07-2013, 01:35 AM)mbz123
(05-20-2013, 09:31 AM)offroaddieselhu I have to optimalizate.
Yes, I must do this too! Looking good on the build and following closely for the turbo infos.
THX
MBZ123
THX
It is the best geometric turbo car from me!
https://www.facebook.com/photo.php?v=550...=2&theater
This post was last modified: 07-09-2013, 03:59 PM by offroaddieselhu.
offroaddieselhu
THX
MBZ123
THX
07-17-2013, 06:55 AM #52
Hi,
I try a bigger cramshaft.
offroaddieselhu
Hi,
Gforce
07-20-2013, 01:37 PM #55
are you using the standard mercedes w460 axles?
Gforce
07-20-2013, 02:03 PM #56
(07-20-2013, 01:37 PM)Gforce are you using the standard mercedes w460 axles?
Hi,
Yes, but I drive very carefully. There is a special lock, but I don't use this. I don't test or use on concret.
One was that I try on concret and firs start I crashed the gear!!! (It was the wants of the costumer.)
Offroaddieselhu
(07-17-2013, 06:55 AM)offroaddieselhu Hi,
Hi,
I think till now the change of cramshaft is succesfull!
Offroaddieselhu
This post was last modified: 07-20-2013, 02:19 PM by offroaddieselhu.
offroaddieselhu
Hi,
Offroaddieselhu
Hi,
Offroaddieselhu
mantahead
07-20-2013, 03:59 PM #57
hi,
did you get cams re-profiled?
mantahead
hi,
07-20-2013, 04:05 PM #58
(07-20-2013, 03:59 PM)mantahead hi,
602 0510601
(07-20-2013, 04:05 PM)offroaddieselhu
602 0510601
602 0510601
This post was last modified: 07-20-2013, 04:25 PM by offroaddieselhu.
offroaddieselhu
602 0510601
602 0510601
602 0510601
07-21-2013, 03:27 AM #59
Hi,
This is an original cramshaft, but from an other car.
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
mantahead
07-21-2013, 05:04 AM #60
(07-21-2013, 03:27 AM)offroaddieselhu
Hi,
Offroaddieselhu
is it n/a cam, have you much more lift?
mantahead
Hi,
Offroaddieselhu
07-21-2013, 06:40 AM #61
Hi,
Offroaddieselhu
https://www.youtube.com/watch?v=dfEVv9RT...h8itXs2hZQ
https://www.youtube.com/watch?v=mKlyK3Ut...h8itXs2hZQ
https://www.youtube.com/watch?v=oZ2G0c2i...h8itXs2hZQ
(07-21-2013, 05:04 AM)mantahead
Hi,
Offroaddieselhu
Hi,
Serie (original) camshaft: intake lift 8,4 mm
outtake lift 9,0 mm
OM602 IDI carmshaft: intake lift: 9,1 mm
outtake lift: 10,0 mm
It is a quite worn camshaft, maybe it is bigger a bit (some decade mm).
Offroaddieselhu
This post was last modified: 07-21-2013, 07:04 AM by offroaddieselhu.
offroaddieselhu
Hi,
Offroaddieselhu
Hi,
Offroaddieselhu
Hi,
outtake lift 9,0 mm
Offroaddieselhu
07-23-2013, 05:36 PM #62
VE tuning
http://www.youtube.com/watch?v=zC1uHsuhd...ture=share
http://www.youtube.com/watch?v=RfB2ozCAw...h8itXs2hZQ
This post was last modified: 07-24-2013, 11:54 AM by offroaddieselhu.
10-27-2013, 12:51 PM #63
This is an other project (OM602) with hybrid turbo. Compressor wheel is 63.
Offroaddieselhu
(10-27-2013, 12:51 PM)offroaddieselhu This is an other project (OM602) with hybrid turbo. Compressor wheel is 63.
Offroaddieselhu
turbo 63mm
This post was last modified: 10-27-2013, 12:56 PM by offroaddieselhu.
offroaddieselhu
Offroaddieselhu
Offroaddieselhu
turbo 63mm
10-27-2013, 05:03 PM #64
so cool!!!!!
How far are you from firing it up?
so cool!!!!!
2996
11-15-2013, 01:36 PM #66
Very nice work to the pump, and everything else really!
2996
11-15-2013, 02:23 PM #67
(11-15-2013, 01:36 PM)2996 Very nice work to the pump, and everything else really!
http://www.superturbodiesel.com/std/imag...s/wink.gif
Smile
This post was last modified: 11-15-2013, 02:24 PM by offroaddieselhu.
offroaddieselhu
Smile
11-16-2013, 12:42 PM #68
(11-15-2013, 02:23 PM)offroaddieselhu
Smile
https://www.youtube.com/watch?v=iiG0Cf9F...h8itXs2hZQ
(11-16-2013, 12:42 PM)offroaddieselhu
Smile
OM602+ bosio powerplus
This post was last modified: 11-16-2013, 12:47 PM by offroaddieselhu.
offroaddieselhu
Smile
Smile
Stamsaas
01-10-2014, 05:14 PM #69
Nice Work you are doing! Big Grin Did you notice big differance with the camshaft? Are they from n/a engine? Smile
And do the 320cdi oilpump fit straight in? Smile
Stamsaas
01-13-2014, 04:55 AM #70
(01-10-2014, 05:14 PM)Stamsaas Nice Work you are doing! Big Grin Did you notice big differance with the camshaft? Are they from n/a engine? Smile
Hi,
Sorry a missed the number. I'll writte the right but I have to look it for.
It's better.
The engine is OM602 without turbo so called prechamber engine.
THe oil pump is fit into it, ony srew you must change.
Offroaddieselhu
offroaddieselhu
Hi,
It's better.
Offroaddieselhu
02-08-2014, 04:09 PM #71
winter fun
https://www.facebook.com/photo.php?v=191317521078237
offroaddieselhu
erling66
SuperDieselVan
294
12-30-2014, 05:45 AM #73
Hi
I can see that you know Bosch VE pumps very wellSmile From which car is the VE pump you use? It looks like it fit directly to the 2.9 adapter
HuhCoolTongue
erling66
Hi
HuhCoolTongue
12-30-2014, 10:33 AM #74
(12-30-2014, 05:45 AM)erling66 Hi
Hi,
I use the original 2.9 pump (Inside parts only)
Tanks the praising words.
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
12-30-2014, 11:40 AM #75
(12-30-2014, 10:33 AM)offroaddieselhu
Hi,
Offroaddieselhu
https://www.youtube.com/watch?v=f1JX7E3wKqA
offroaddieselhu
Hi,
Offroaddieselhu
erling66
SuperDieselVan
294
12-31-2014, 04:20 AM #76
Every 2.9 VE pump I have seen are electronically controlled and looks like this:
[Image: 29vepump_zps24234fe6.jpg]
So is there also some mechanical ve pumps? or do you use the electrical pump and rebuild it to be mechanical? Thank you for info Smile
HuhCoolTongue
erling66
HuhCoolTongue
12-31-2014, 05:40 AM #77
(12-31-2014, 04:20 AM)erling66 Every 2.9 VE pump I have seen are electronically controlled and looks like this:
Hi,
I put the mechanical parts into this socalled house of VE pump.
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
EDH_Performance
01-05-2015, 05:49 AM #78
(12-31-2014, 05:40 AM)offroaddieselhu
Hi,
Offroaddieselhu
Does this Fiat 1300D pump housing have the right axel and nose dimensions to fit straight into a 290D adapter?
EDH_Performance
Hi,
Offroaddieselhu
01-05-2015, 06:25 AM #79
(01-05-2015, 05:49 AM)EDH_Performance
Hi,
Offroaddieselhu
Hi,
You should the axel correct to 20mm or to use some 20mm axel.
Otherwise it is perfect to this aim.
Or the 1.6 Golf D house.
offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
Hi,
offroaddieselhu
EDH_Performance
01-05-2015, 06:37 AM #80
(01-05-2015, 06:25 AM)offroaddieselhu
(12-31-2014, 05:40 AM)offroaddieselhu Hi,
Offroaddieselhu
Hi,
offroaddieselhu
Ahh, okey.
Is the 1.3d and vw 1.6d stock axel 17mm or around there?
And do you bore out the housing to fit the bigger 20mm shaft?
This post was last modified: 01-05-2015, 06:47 AM by EDH_Performance.
EDH_Performance
Offroaddieselhu
Hi,
offroaddieselhu
Ahh, okey.
01-05-2015, 07:54 AM #81
(01-05-2015, 06:37 AM)EDH_Performance
(01-05-2015, 05:49 AM)EDH_Performance Does this Fiat 1300D pump housing have the right axel and nose dimensions to fit straight into a 290D adapter?
Hi,
offroaddieselhu
Ahh, okey.
from 17 to 20mm
offroaddieselhu
offroaddieselhu
Hi,
offroaddieselhu
Ahh, okey.
from 17 to 20mm
offroaddieselhu
raidaru
01-05-2015, 09:28 AM #82
Nice work! I always asked myself why nobody tunes the VE 602 engine, and here I find somebody at last! This engine is pretty much simmilar to 2.5 tdi AEL, 140 hp from VW. They upgrade the nozzles, turbo,IC and software and there they are 300hp and 600 nm! Why can't be done the same thing with the 602 engine, as it is even bigger? With a 12mm pump head even 400+ hp powers should be reachable! What do u think offroaddiesel, as u're the 602 VE expert on this forum? Tongue
raidaru
01-05-2015, 10:25 AM #83
(01-05-2015, 09:28 AM)raidaru Nice work! I always asked myself why nobody tunes the VE 602 engine, and here I find somebody at last! This engine is pretty much simmilar to 2.5 tdi AEL, 140 hp from VW. They upgrade the nozzles, turbo,IC and software and there they are 300hp and 600 nm! Why can't be done the same thing with the 602 engine, as it is even bigger? With a 12mm pump head even 400+ hp powers should be reachable! What do u think offroaddiesel, as u're the 602 VE expert on this forum? Tongue
Hi,
I think there isn't any nozzle to fitting it. Sotherefore I would make easier 400+ hp from 1.9 TDI.
From ths engine I would propose 320-350 Hp. (I'm making this)
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
