STD Other Projects W124 250 D - OM603 + 716 Gearbox Superturbo Transformation
  • 2 Vote(s) - 4.5 Average
Pages (2): Previous 1 2
swatmugga
06-01-2015, 01:18 PM #51
A short video here:
120 cc
China HX 35
Big Intercooler
Big Fuel Line
Original Prepump (i will install a harder spring for high RPM Power)
150 Bar Injectors
https://youtu.be/MSi9SRsG0I8
swatmugga
A short video here:
120 cc
China HX 35
Big Intercooler
Big Fuel Line
150 Bar Injectors
swatmugga
06-18-2015, 02:21 PM #52
https://www.youtube.com/watch?v=fAuPN8ta...e=youtu.be
5,8S from 120 --> 170 kmh
Few things changed.
Going to mount Sportline Springs in the next weeks to get the car better drivable.
[Image: x9gpivha946.jpg]
This post was last modified: 06-18-2015, 02:21 PM by swatmugga.
swatmugga
Few things changed.
PedroFerreira
09-09-2015, 04:44 PM #53
hello swatmugga how do you put the speedo working?
PedroFerreira
swatmugga
09-09-2015, 05:04 PM #54
Same solution as hansebanger but mine only works above 40 kmh.. i think before the imput signal is to weak.
Tacho from E420 E500 and then using an Speedohealer v2 for converting the ABS signal from the differential to a correct value (y)
swatmugga
swatmugga
PedroFerreira
10-04-2015, 06:09 PM #56
can you make an video of 100 to 200kmh?
PedroFerreira
swatmugga
11-18-2015, 08:10 AM #57
I will go to dyno soon Wink
Bilstein B8 Dampers with Sportline springs, shortened 1/2 turn
[Image: 20151117_103310.jpg]
[Image: 20151117_131655.jpg]
[Image: IMG-20151118-WA0010.jpg]
New Sinter clutch, total daylie drivable...
[Image: 12112090_1044708108913456_4362963153152125436_n.jpg]
swatmugga
swatmugga
11-27-2015, 12:25 PM #58
[Image: 12289682_1063579560359644_4574503816525413148_n.jpg]
swatmugga
11-27-2015, 06:04 PM #59
275kw??
275kw??
swatmugga
11-27-2015, 07:21 PM #60
245kW and 600nm Smile
swatmugga
Anjay1
11-27-2015, 10:57 PM #61
That makes 328 hp and 442 foot pounds of torque! Excellent result for dd.
Anjay1
11-28-2015, 12:39 AM #62
Yeah that's a badass result!
That's sweet, I hope for mine to run 3/4 that good someday Big Grin
swatmugga
11-28-2015, 04:06 AM #63
and only with 1.3 Bar of boost... very much torque i have to check why i have so much torque lost at high rpm
swatmugga
Anjay1
11-28-2015, 07:28 AM #64
Engines are loosing torque at high rpm due to deminishing volumetric efficiency. In 12 valve engine it happens sooner than 24 valve. You can try raise boost to see if that will change results.
Anjay1
11-28-2015, 10:09 AM #65
Swatmugga, here's a page with some good intercooler math.
https://takemebeyondthehorizon.wordpress...selection/
I ran the math, thinking of making 350hp on my 603 and it looks pretty ugly considering the front end of a w124. The only way to avoid massive restriction in the intercooler is to use a vertical flow core. I'm going to try this one, which is barely adequate in terms of flow according to the IC page I linked to.
[Image: 1.jpg]
[Image: 1.jpg]
bruno_pinho
11-29-2015, 08:53 AM #66
Do not you think these numbers a bit too animators?
bruno_pinho
mcwfxx
11-30-2015, 12:53 PM #68
(11-30-2015, 11:24 AM)swatmugga https://www.youtube.com/watch?v=ufCItpfCEaU
That's awesome! love how inadequate the exhaust extractor is for the mighty std!!!
W639 Vito OM606 + 722.6 STD - in progress
Current progress: engine in, gearbox in, bumper bar modified to accept w210 radiator, audi electric fan, very tight squeeze, interior stripped out ready for new seats (w211) and custom dash with w211 clocks controlled by arduino with split fuel gauge covering main tank and auxiliary for Veg Oil ...
- DSL1 ECU for Electronic OM606 Pump (currently fitting wiring)
Next; 722.6 Controller, HX40 with homemade manifold, Air-to-water intercooler, homemade exhaust, MOT.... One day!
mcwfxx
swatmugga
12-16-2015, 01:57 PM #69
HX 40 Super 14cm with wastegate and billet wheel.
If 480 Engine HP are possible would be nice.
[Image: IMG-20151216-WA0013.jpg]
This post was last modified: 12-16-2015, 01:59 PM by swatmugga.
swatmugga
PedroFerreira
12-16-2015, 02:39 PM #70
480hp in om603....dailly car?
PedroFerreira
swatmugga
12-16-2015, 04:55 PM #71
ah sorry forget, i will swich to om606 too Wink allready in garage
swatmugga
12-22-2015, 09:41 AM #72
(12-16-2015, 04:55 PM)swatmugga ah sorry forget, i will swich to om606 too Wink allready in garage
Need more pictures then man!
