STD Tuning Engine fuel line size
fuel line size
fuel line size
yota4life
08-17-2016, 10:46 PM #1
What's the fuel line size from the fuel filter to the sides of the ip the clear ones. Mine cracked ordered the wrong size. And haven't been able to fined the size anywhere online.
yota4life
NZScott
HX30W 73/44mm
398
08-17-2016, 11:43 PM #2
Don't know what engine you're talking about but if it's a 617 (which most 'muricans seem to have) try slipping 5/16" over the barbs but leave the clear hose still on the barb.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
zeeman
08-18-2016, 01:34 AM #3
(08-17-2016, 10:46 PM)yota4life What's the fuel line size from the fuel filter to the sides of the ip the clear ones. Mine cracked ordered the wrong size. And haven't been able to fined the size anywhere online.
They are 6mm, I heat up the banjo fitting with a heat gun and push the tubing on and use a pex tubing crimp clamp. Works great and is tight.
This post was last modified: 08-18-2016, 01:37 AM by zeeman.
zeeman
Tobulus
08-18-2016, 08:16 AM #4
If you dont heat it up, you dont need the clamps. Thats the way truck brake piping is done.
Tobulus
