STD Tuning Drivetrain Differential
Differential
Differential
Pages (2): Previous 1 2
F.R.A.S
01-28-2015, 02:06 PM #51
So a lower gear sits closer to the center??? Machine those millimeters or schim it if it's the other way around in other words. Sounds to easy...
(01-27-2015, 06:08 PM)raysorenson The flange that the ring gear bolts to has different spacing L to R.
F.R.A.S
erx
w202 om606
323
01-28-2015, 03:24 PM #52
Differences are about 10mm and there isn't much to machine. 3.07 ASD on left and 2.65 opened on right.
[Image: IMG_5011_zpsaff0f7ca.jpg]
This post was last modified: 01-28-2015, 03:24 PM by erx.
erx
swampmonkey
hx40 super
280
01-28-2015, 06:43 PM #53
(01-28-2015, 03:24 PM)erx Differences are about 10mm and there isn't much to machine. 3.07 ASD on left and 2.65 opened on right.
that 2.65 looks like it has seen better days huh? how did that happen? Big Grin
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
erx
w202 om606
323
01-29-2015, 04:11 AM #54
(01-28-2015, 06:43 PM)swampmonkey
http://i236.photobucket.com/albums/ff209...f0f7ca.jpg
I bought them few years ago as they are, 2.65 was dry because front seal was leaking but I don't understand how that pin is so worn-out. Big Grin Because 2.65 ASD is hard to find I bought 3.07 ASD and I was planning to swap the internals but then I realized that there's different offset.
erx
F.R.A.S
01-29-2015, 01:01 PM #55
Such awesome info, I love you guys Smile
Can you put then bearing down on a flat surface and measure both and post the numbers???
F.R.A.S
Matej
02-12-2015, 11:10 PM #56
Hello gentlemen,
What is the best W201/W204 differential (strength and ratio-wise) for an OM60x swap? It will be getting welded solid, so I am only interested in open differentials.
The car will be used for occasional drift events, but I would also like to be able to drive on the highway at reasonable RPM's. Smile
Irony.cc
Matej
Hello gentlemen,
Irony.cc
swampmonkey
hx40 super
280
02-13-2015, 01:15 PM #57
(02-12-2015, 11:10 PM)Matej Hello gentlemen,
depends on the gearbox...  a 1:1 a 2.65 might be pretty awsome (from 300tdt and others) , a 0.8 in fifth might be good with a 3.07diff
daily driver
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
02-13-2015, 01:15 PM #58
Weight of the vehicle is almost as important and projected power output.
Austincarnut
05-03-2017, 09:32 PM #59
Has anyone made any progress with this subject?
Austincarnut
 30 Guest(s)
 30 Guest(s)
