STD Tuning Engine OM605 dyno
  • 3 Vote(s) - 5 Average
jeemu
457
02-17-2010, 10:41 AM #51
Some new parts Cool
[Image: img2454217.jpg]
[Image: img2467248.jpg]
[Image: img2468427.jpg]
[Image: img2469442.jpg]
jeemu
Some new parts Cool
Tymbrymi
Klatta Klatta
185
02-17-2010, 11:19 AM #52
Is that a custom timing advance device, and what is the last image a picture of?
John Robbins
Tymbrymi
John Robbins
DervTuning
02-17-2010, 12:30 PM #53
They look like adjustable cam timing gears; very nice Big Grin!
I wonder what the optimal degrees (+/-) will yield after rolling road testing Cool?
(02-17-2010, 11:19 AM)Tymbrymi Is that a custom timing advance device, and what is the last image a picture of?
DervTuning
jeemu
457
02-18-2010, 02:36 AM #54
Yes that is modded advanse device and last picture is adjustable cam wheel like DervTuning say.
jeemu
Tymbrymi
Klatta Klatta
185
02-18-2010, 10:06 AM #55
Awesome! Thanks for the info guys... keep it coming! Smile
John Robbins
Tymbrymi
John Robbins
02-20-2010, 10:43 AM #56
jeemu, how many CM2 is your holset turbine's nozzle area?
This post was last modified: 02-20-2010, 10:44 AM by ForcedInduction.
jeemu
457
02-20-2010, 03:08 PM #57
(02-20-2010, 10:43 AM)ForcedInduction jeemu, how many CM2 is your holset turbine's nozzle area?
I have Master Power turbo, it has turbinehousing nro 16.
jeemu
HoleshotHolset
02-20-2010, 03:47 PM #58
More of the Finnish Superturbo secrets are being revealed. Awesome!
Who made the custom/modified timing advance mechanism? Looks like nice work!
Cheers,
Matt
'07 W211 OM642
HoleshotHolset
Cheers,
Matt
'07 W211 OM642
Mercy
02-22-2010, 12:38 PM #59
(02-20-2010, 03:08 PM)jeemu
With 16cm2 turbinehousing what do you have for exhaust temp?
Mercy
jeemu
457
02-22-2010, 12:58 PM #60
(02-22-2010, 12:38 PM)Mercy
Hi. Here is now winter so not much crip to test car, but now temp is aroun 500-550 celcius.
Today i send pump Mynä-Diesel and they change it new elements.
jeemu
Mercy
02-22-2010, 03:27 PM #61
(02-22-2010, 12:58 PM)jeemu
okey .. Why I ask is that I do not really know what to have for the turbinehousing to my 300 24vHuh why sending to Mynä?
Mercy
jeemu
457
02-22-2010, 04:26 PM #62
(02-22-2010, 03:27 PM)Mercy
How much you want power?
They change new elements= more fuel Big Grin
jeemu
Mercy
02-23-2010, 03:18 PM #63
(02-22-2010, 04:26 PM)jeemu
I'm aiming to at least 500hk .. Consider a turbo from Borg Warner S472 with 72mm compressor and 83mm turbine wheel but I do not really know what turbine A / R size I should buy?
Are you going for 8mm size??Big Grin
Mercy
jeemu
457
02-23-2010, 04:12 PM #64
(02-23-2010, 03:18 PM)Mercy
If 500hp is enough that turbo is big for that. There go same turbo what i have. 65mm compressor and 69mm turbine wheel and 16 turbinehousing. What changes you gona do engine at you can reach that 500hp.
No. New 7mm gome pump. 170cm3
(02-20-2010, 03:47 PM)HoleshotHolset More of the Finnish Superturbo secrets are being revealed. Awesome!
Cheers,
Matt
Secrets?? I modded that timing wheel my self.
This post was last modified: 02-23-2010, 04:14 PM by jeemu.
jeemu
Cheers,
Matt
tomnik
02-24-2010, 12:51 AM #65
Jeemu,
how can a 7mm element make 170ccm??
Effective stroke has to be about 4.4mm!
Does Myna regrind the cam Huh?
Tom
This post was last modified: 02-24-2010, 07:06 AM by tomnik.
tomnik
Jeemu,
Tom
jeemu
457
02-24-2010, 08:52 AM #66
(02-24-2010, 12:51 AM)tomnik Jeemu,
Tom
I dont know. I just send the pump there Smile
jeemu
Tom
02-24-2010, 09:01 AM #67
(02-24-2010, 12:51 AM)tomnik Does Myna regrind the cam Huh?
I have heard that they do, maybe an old post from schumans? They do the elements and grind the cam and add the external adjustments.
Mercy
02-25-2010, 03:42 PM #68
Okey maby its little too bigBig Grin but Im aming 500-600hk and i am working on head porting, custom manifolds bigger valves etc..) Shift size of the fuel lines and filters ,Mod the injection timing device and mynä 170ccm pump of courseSmile I thought you had 170ccm pump with the good dyno you showed us .. what did youre pump leave previous?
Mercy
jeemu
457
02-26-2010, 06:10 AM #69
(02-25-2010, 03:42 PM)Mercy what did youre pump leave previous?
150cm3
jeemu
150cm3
jeemu
457
03-09-2010, 03:39 PM #70
Now is new pump, engine sounds like stock, dosent krook at all Cool
I installed adjustable cam wheels also and adjust intake cam, damm that thing take revs fast.
[Image: img2496832.jpg]
jeemu
Mercy
03-14-2010, 10:00 AM #71
(03-09-2010, 03:39 PM)jeemu Now is new pump, engine sounds like stock, dosent krook at all Cool
Have you mounted modified cams to ??
Mercy
jeemu
457
03-14-2010, 11:16 AM #72
(03-14-2010, 10:00 AM)Mercy
Not yet. Whats the rush Smile
I went dyno today. Not much better but some.
jeemu
Mercy
03-14-2010, 05:18 PM #73
That was a nice dyno but i thought it they would be more power with 170cc elements Huh Do u got the same boost pressure??
Mercy
jeemu
457
03-14-2010, 06:10 PM #74
(03-14-2010, 05:18 PM)Mercy That was a nice dyno but i thought it they would be more power with 170cc elements Huh Do u got the same boost pressure??
Its not just fuel what makes power. i think 190hp/ltr is good number on stock cams, or is it? Not seen too many 570hp 6syl dyno graphs.
100hp/sylinder. That will come there, just wait Smile
jeemu
Mercy
03-15-2010, 06:17 PM #75
(03-14-2010, 06:10 PM)jeemu
Im wery impressed of your dyno 190hp/ltr is wery goodSmile
I thought it was the fuel that limited for u to get 500hk
It becomes wery interesting when you run the dyno with the regrinded cams Smile
Mercy
DervTuning
03-18-2010, 11:09 AM #76
Very nice dyno output you have there; lots of area under the curve. You already have enough power for 10 second 1/4 mile (~400m) runs Cool
It is easy to forget this is a 2.5L 5 cylinder with that power output.
Do you have a video of the new dyno run?
DervTuning
jeemu
457
03-18-2010, 01:51 PM #77
(03-18-2010, 11:09 AM)DervTuning Very nice dyno output you have there; lots of area under the curve. You already have enough power for 10 second 1/4 mile (~400m) runs Cool
Hi. Yes some people just see the max power, they dont think the engine size at all. I think allways what size engine is. Then i see how good tuner is. We filmed first dyno pull, but i havent had video yet.
I upload it yotube when i got it my own computer.
jeemu
Tymbrymi
Klatta Klatta
185
03-25-2010, 11:31 AM #78
(03-14-2010, 11:16 AM)jeemu I went dyno today. Not much better but some.
Nice!!! Cool It may not be much better in the peak number, but it sounds like you've added a lot of refinement to it since the last pull (things like ALDA functionality).
What do you think your limiting factors are and why did you stop at 477? EGTs too high, nailing, max torque, or just experience?
Thanks for keeping us up to date!!
John Robbins
Tymbrymi
John Robbins
Tymbrymi
Klatta Klatta
185
03-25-2010, 01:31 PM #79
(12-22-2009, 06:37 AM)jeemu Timing is 16degrees advance. Dont know what it is in high rpm.
Sorry to bring this back up... but what method are you using to check the timing? Is this the method?
http://www.w124performance.com/service/w...1-8240.pdf
If that's the case, do you have it set to 16* ATDC or have you advanced it 16* so that it's now 0* ATDC? Or am I missing something completely?
The reason I ask is that in the 10mm element thread, shredator retarded his timing from 26* BTDC to 15* BTDC (BTDC since he's using a different measuring technique). I would think with the larger elements you would have to retard your static timing... Then again, none of my cars make 470 HP!! Wink
John Robbins
Tymbrymi
John Robbins
jeemu
457
03-25-2010, 02:28 PM #80
(03-25-2010, 01:31 PM)Tymbrymi
Hi-. Now i have 20 BTDC. I try 18 BTDC but it bush only 456hp.
Back 20 BTDC numbers is 477hp.
I not use that kind tools when timing pump.
I use this
[Image: IP__lock_tool2.jpg]
PS. That new pumpu sound just like original. No klak klak sound Cool
Some new parts made.
[Image: img2518414.jpg]
[Image: img2519508.jpg]
This post was last modified: 03-25-2010, 02:48 PM by jeemu.
jeemu
I use this
Tymbrymi
Klatta Klatta
185
03-25-2010, 03:53 PM #81
(03-25-2010, 02:28 PM)jeemu Hi-. Now i have 20 BTDC. I try 18 BTDC but it bush only 456hp.
The stock setting using that tool is 15* ATDC right? So you have yours advanced by 35*? Exclamation
(03-25-2010, 02:28 PM)jeemu PS. That new pumpu sound just like original. No klak klak sound Cool
Nice! Glad to know that it's possible to get rid of all the clattering! Smile
What is that? An adjustable wastegate actuator of some kind?
Would you mind explaining how you decide when you've reached the max power for that setup? I'm still curious why you decided that 477HP was as high as you wanted to go.
Thanks again!!!
John Robbins
Tymbrymi
Thanks again!!!
John Robbins
jeemu
457
03-25-2010, 04:23 PM #82
(03-25-2010, 03:53 PM)Tymbrymi Would you mind explaining how you decide when you've reached the max power for that setup? I'm still curious why you decided that 477HP was as high as you wanted to go.
Thanks again!!!
That 477 dyno made because i got the new pump, so we can see next dyno run how much that bush out with new cams.
190hp/ltr is ok, but not enough
jeemu
Thanks again!!!
jeemu
457
03-26-2010, 04:47 PM #83
(03-25-2010, 03:53 PM)Tymbrymi What is that? An adjustable wastegate actuator of some kind?
Its ready. Do you now guess what that is?
[Image: img2520631.jpg]
[Image: img2520632.jpg]
[Image: img2520633.jpg]
jeemu
DervTuning
03-29-2010, 11:06 AM #84
Looks like an adjustable alda Cool
I bet there is, but do you have a shaft/screw seal for the adjustment screw as well?
Nice work!
DervTuning
Nice work!
jeemu
457
04-02-2010, 08:08 AM #85
(03-29-2010, 11:06 AM)DervTuning Looks like an adjustable alda Cool
Nice work!
Yep that is alda. Not cut fuel in big boost any more
jeemu
Nice work!
mbenzo300td
04-14-2010, 03:48 AM #86
Jeemu, Where can I find some fuel lines like the ones in your picture. Mine keep cracking.
(12-05-2009, 03:48 PM)jeemu
(12-05-2009, 02:37 PM)DervTuning It is not the intercooler or charge piping that causes the restriction, but rather the inertia from the large diameter compressor and turbine wheels.
I've noticed this as well using a Holset HX40 using a gasser turbo gauge, and would see a bit of vacuum upon revving the engine. It is more pronounced when the engine/turbo is cold. I would imagine the benefit is even greater with a larger turbo than the HX40.
In addition, allowing the extra air into the engine, without any vaccum, will feed more exhaust products to the turbine wheel, decreasing the time for the turbo to spool, creating boost faster.
(12-05-2009, 01:50 PM)Tymbrymi
(12-04-2009, 03:23 PM)jeemu You are 100% correct Cool
Awesome! Thanks for the info! Cool So I guess you've seen some benefit from it in your testing so far? That's very interesting since I didn't think the huge intercoolers you use would really pose that much of a restriction.
Smile
DervTuning is right. Big wheel Turbo spins "slowly" at low rpm, so engine have more air for breather valve and makes engine low end and turbo spooling better. This Master Power wheels are 65mm kompressor and 69mm turbine.
Here is few photo of the engine.
[Image: img2376261.jpg]
[Image: img2344783.jpg]
[Image: img2292038.jpg]
mbenzo300td
Smile
muuris
OM605
318
04-14-2010, 07:59 AM #87
(04-14-2010, 03:48 AM)mbenzo300td Jeemu, Where can I find some fuel lines like the ones in your picture. Mine keep cracking.
Stock lines won't crack for no reason at all. Usually this is due to poor pump mounting.. So, do you have all the brackets mounted between pump and engine?
muuris
gsxr
Gone to the M119 dark side
103
04-14-2010, 08:43 AM #88
You also need all the injector line clips installed - if they are missing, you can end up with cracked lines:
[Image: inj_line_clips.jpg]
[Image: inj_line_clips1.jpg]
[Image: inj_line_clips2.jpg]
Dave M.
Boise, ID, USA
1997 E420 - 149kmi (Bugeyes)
1994 E420 - 136kmi (Blondie)
1994 E500 - 116kmi (Q-ship)
1992 500E - 179kmi (Mach 5)
Click here for my website!
gsxr
Dave M.
Boise, ID, USA
mbenzo300td
04-14-2010, 12:42 PM #89
My clip situation is a little sketchy. However I have taken the lines off and made sure there is no tension on them, they are all bent to fit precise. Ive gone through 3 #3's and 2 # 2's they all have cracked at the base. I posted about finding 617 dual line clips but got no response. The plastic 603 clips break to easy in my opinion. However, im still out of comission until i find a fuel line.
(04-14-2010, 08:43 AM)gsxr You also need all the injector line clips installed - if they are missing, you can end up with cracked lines:
This post was last modified: 04-14-2010, 05:36 PM by ForcedInduction.
mbenzo300td
jeemu
457
04-14-2010, 03:08 PM #90
mbenzo300td you can find those stronger pipes from diesel parts sale shop.
I can inform you exact size when i go work tomorrow. Dont remember anymore.
jeemu
mbenzo300td
04-14-2010, 03:18 PM #91
Thank you Jemuu.
mbenzo300td
Thank you Jemuu.
04-14-2010, 05:41 PM #92
Do you have any loping problems? The VP44 Cummins owners often have that issue after installing larger ID injection lines.
jeemu
457
04-15-2010, 01:07 AM #93
(04-14-2010, 05:41 PM)ForcedInduction Do you have any loping problems? The VP44 Cummins owners often have that issue after installing larger ID injection lines.
I m not notice any. Works fine. Those my pipes has thicker wall than orig
jeemu
mbenzo300td
04-17-2010, 05:49 PM #94
No luck on injection lines. Ive tried most all of the diesel shops in seattle with the exeption of bosch. Anyone know where I might look?
mbenzo300td
Mercy
05-23-2010, 05:11 PM #95
How is it going for you? I saw some new videos on youtubeWink
Mercy
jeemu
457
05-24-2010, 04:50 AM #96
(05-23-2010, 05:11 PM)Mercy How is it going for you? I saw some new videos on youtubeWink
Now got drag radials, so i can test it on 1/4mile next month.
Car is worked fine. Some injector test is done on the dyno.
jeemu
Alastair E
Moderator?--Nah...
266
05-24-2010, 08:46 AM #97
(02-24-2010, 08:52 AM)jeemu
Tom
Its the way pumps are set....
A certain quantity Per 1000 Strokes....
In this case, 170ccm/1000
So, by rough calcul;ation the engine will be burning 6 litres per minute at 6000 RPM under full rack.....!!
This post was last modified: 05-24-2010, 08:51 AM by Alastair E.
[Image: 300TDnoplate.jpg]
Alastair E
Tom
Mercy
05-24-2010, 05:53 PM #98
(05-24-2010, 04:50 AM)jeemu
okey i have planed to do injector test also.. But maby you can tell me what you find out?? Angel
Mercy
jeemu
457
05-26-2010, 05:25 PM #99
(05-24-2010, 05:53 PM)Mercy
Must test some more. Max torgue comes 500rpm sooner than originals.
jeemu
GREASY_BEAST
05-27-2010, 04:58 PM #100
(05-26-2010, 05:25 PM)jeemu Must test some more. Max torgue comes 500rpm sooner than originals.
Wow that's interesting. What does it do to the dyno curve shape?
GREASY_BEAST
 57 Guest(s)
 57 Guest(s)
