STD Tuning Drivetrain Strong transmission for G-Wagen???
gvp
01-18-2010, 08:52 AM #1
Hello to everybody!!!I have a G-wagen and am planning to put the om606 with myna pump and a big turbo!!!
As will have much torque and as i want a manual gearbox,i decided to put one from Sprinter!!!
The code is:711.620 G32-5 and the gear ratio:
5.05:1
2.6:1
1.52:1
1:1
0.78:1
R4.76
I know that the vans have stronger transmissions than normally cars!!!
What do you believe???does it nice choise??
gvp
5.05:1
2.6:1
1.52:1
1:1
0.78:1
R4.76
01-20-2010, 10:03 AM #2
Interesting, does the sprinter transmission maatch up? I am suprised that is not a granny gear.
01-20-2010, 11:28 AM #3
5.05 to 2.6 is a granny gear if I'd ever call it one! Even the getrag 4-speed 240D only had a 4.23 1st.
gvp
01-20-2010, 02:21 PM #4
Sometimes for off-road use it's necessary the first short gear!!!Haw also an overdrive 5 gear....
All the transmissions of the trucks and commercial vans are stronger than normal cars....
Do you believe that will hold 350Hp???
gvp
01-26-2010, 03:50 PM #5
(01-20-2010, 11:28 AM)ForcedInduction 5.05 to 2.6 is a granny gear if I'd ever call it one! Even the getrag 4-speed 240D only had a 4.23 1st.
It's wierd that 5th is an OD tho.. that was the only number I was really looking at.
Syncro_G
0-60 in 29 sec
280
01-28-2010, 12:15 AM #6
(01-20-2010, 02:21 PM)gvp Sometimes for off-road use it's necessary the first short gear!!!Haw also an overdrive 5 gear....
gvp - that looks like a great gear ratio. the wide spread should suite the G-wagen nicely. Kind of like a mix between the 711.117 and the 711.116 transmissions.
Probably not great for racing on streets but good for off road.
-Christian
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
-Christian
'75 240D 4-Speed
gvp
01-28-2010, 05:38 PM #7
Quote:gvp - that looks like a great gear ratio. the wide spread should suite the G-wagen nicely. Kind of like a mix between the 711.117 and the 711.116 transmissions.
-Christian
I am very interested for offroad use,but i like to go fast also at highway with the fifth overdrive!!!Wink
Hope that ll holds the torque!!!
gvp
-Christian
krashappy
606 Junkie
14
01-29-2010, 02:23 PM #8
Will you convert the ECU as well, the trans you describe is an electronic AT isn't it?
Which AT is currently under the hood ?
KRASHAPPY
93 G350DT 606 conv daily
94 SDL 350 606 conv
98 E300DT stock
99 E320 wgn 606 conv
krashappy
KRASHAPPY
94 SDL 350 606 conv
98 E300DT stock
gvp
01-29-2010, 05:21 PM #9
(01-29-2010, 02:23 PM)krashappy Will you convert the ECU as well, the trans you describe is an electronic AT isn't it?
It's a manual trabsnission!!!
The car isn't ready yet,but ll have om606,myna pump and holset hx35...
gvp
GREASY_BEAST
01-31-2010, 01:03 PM #10
Sorry to throw a wrench into the mix. I don't know much about these transmissions, but I gather some people throw big american V8's in front of them... Maybe someone with some experience with these things will chime in.
http://en.wikipedia.org/wiki/Toyota_R_transmission
GREASY_BEAST
 7 Guest(s)
 7 Guest(s)
