STD Tuning Engine Dumb HX40 turbo question...
E300TSC
Turbo-Supercharged
321
05-25-2010, 10:10 AM #1
OK, I have this HX40 but I have yet to determine what type of intake flange it has despite a throrugh searching of the internet. So, I'm trying to find out:
Do all HX40's have the same inlet flange?
If so, what type is it - T3, T4, T6?
Would it be easier to just fab up my own flange since I'm making the whole manifold any way?
Thanks!
E300TSC
Thanks!
Alastair E
Moderator?--Nah...
266
05-25-2010, 12:11 PM #2
As far as I know, it is usually a T4 flange.....
Check the Holset site, which has the flange details on, although that page seems to take a while!
Measure up your current flange and compare...
These guys make complete manifolds for HX40 to 605 and 606, they also supply the 'blanks' (Flanges)
http://translate.google.com/translate?js...auto&tl=en for making up your own pipes..
This post was last modified: 05-25-2010, 12:14 PM by Alastair E.
[Image: 300TDnoplate.jpg]
Alastair E
05-25-2010, 12:13 PM #3
Should be a T3. Holset didn't go any bigger on them until the HX50 range was developed.
dieseljunky
04-23-2012, 03:55 PM #4
The HX40 came in both T3 and T4 flanges with many variations in comp wheel, turbine wheel, and exhaust housing sizes.
2001 Dodge Ram 2500 Cummins 24V 4x4 5spd - 3600# SD Clutch from Kenny's Pulling Parts - Stage 5 Jammer Nozzles - AEM Intake - Edge Juice w/Attitude - Glowshift Boost, Oil Temp, Trans Temp - Leveled - Raptor 150 - 1/2" lines from tank to VP - Recon Smoked Cab Lights
1983 Mercedes Benz 300D Auto - Stock minus short ram intake
dieseljunky
dieselmerc
04-24-2012, 04:00 PM #5
Hx40 has 3 sizes, t3, t4 and bigger t4 (89x70?) for size 19 on exhaust
dieselmerc
05-01-2012, 02:53 PM #6
my smalest, first turbine was 16cm it was T3. now its 17cm housing T4 on my hx40.
hansebanger77
dieseljunky
05-02-2012, 12:09 AM #7
I had a T4 housing that was a 19cm. I believe they came with a 20cm as well. A T3 16cm should be the smallest housing available for an HX40
dieseljunky
