STD Tuning Drivetrain s10 5-speed conversion
cbryan0222
09-04-2010, 12:11 AM #1
I am going to put a Mercedes 300d turboed motor in an s10 or a ford ranger. I am just curious to see if anyone has tried this yet and if it is possible to use a five speed out of one of these trucks with a little modifying? Any information would be very helpful.
cbryan0222
09-04-2010, 12:19 AM #2
(09-04-2010, 12:11 AM)cbryan0222 I am going to put a Mercedes 300d turboed motor in an s10 or a ford ranger. I am just curious to see if anyone has tried this yet and if it is possible to use a five speed out of one of these trucks with a little modifying? Any information would be very helpful.
It can be done. Would probably need a custom intermediate plate or an adapter plate. Rudolf_Diesel is in the process of adapting a Ford belhousing style Tremec transmission to his 300SD.
Here is a thread of a Peachparts.com member custom adapting a Ford 5 speed. It's a shame he got a little flak from some purist members though.
http://www.peachparts.com/shopforum/show...p?t=283411
4x4labs offers an adapter plate for GM transmissions.
http://www.4x4labs.com/products/diesel-conversions/
ben2go
Diesel Dumby
129
09-14-2010, 01:29 PM #3
I am planning an OM617 conversion on my 1990 Mercury Blue Max Cougar.My plan is to use a Mercedes manual bolt on bell housing,240D flywheel and pressure plate.Then use a stock 5.0L Thunder Bird/Cougar M5R2 5 speed or a Camaro/Firebird T56 6 speed transmission and the appropriate pressure plate.The transmissions I listed have the shifter in the wrong location for a truck,but you get the idea.Just use the transmission of your choice.You may need a spacer/adapter to mate the transmission to the bell housing.I am hoping that I can get away with re-drilling the bell housing or transmission mounting flange.
As far as the OM61x,the oil pan sum is on the front.In my conversion I will be forced to notch my K member and reshape the back of the oil pan sum.
Do a search for OM617 on these sights and a lot of conversions with pics will come up.
http://www.dieselbombers.com/
http://www.4btswaps.com/forum/index.php
Here's what they look like.Not sure what bell housing,transmission and transfer case that is. Here's his website http://www.seriestrek.com/109.html
[Image: together3.jpg]
I should add that I am also looking at dropping an OM617 into my 2001 Ranger 2wd.It has A arm front suspension,coil springs,and rack n pinion steering.May have to loose the rack for a traditional steering box.I will use a 5 speed M5R2 transmission out of a 4.2L V6 Ford F150.
This post was last modified: 09-14-2010, 01:38 PM by ben2go.
ben2go
cbryan0222
09-15-2010, 09:25 PM #4
(09-14-2010, 01:29 PM)ben2go I am planning an OM617 conversion on my 1990 Mercury Blue Max Cougar.My plan is to use a Mercedes manual bolt on bell housing,240D flywheel and pressure plate.Then use a stock 5.0L Thunder Bird/Cougar M5R2 5 speed or a Camaro/Firebird T56 6 speed transmission and the appropriate pressure plate.The transmissions I listed have the shifter in the wrong location for a truck,but you get the idea.Just use the transmission of your choice.You may need a spacer/adapter to mate the transmission to the bell housing.I am hoping that I can get away with re-drilling the bell housing or transmission mounting flange.
i have also considered using a ranger. just depends on which truck comes at the right price. i also have a ford with a 4.2 5-speed and thought that it would be geared about right. i just didn't know if it'd work out right or if a 240d fly wheel and pressure plate would be strong enough?
cbryan0222
ben2go
Diesel Dumby
129
09-16-2010, 11:41 AM #5
The stock 240D flywheel is pretty beefy and an aftermarket pressure plate will have more clamping force than a factory unit.The clutch disc for the 4.2 should be fine if the diameter is close fit to the 240D fly wheel.IIRC,some of the Rangers did use a version of the M5R2.
ben2go
cbryan0222
09-16-2010, 09:37 PM #6
(09-16-2010, 11:41 AM)ben2go The stock 240D flywheel is pretty beefy and an aftermarket pressure plate will have more clamping force than a factory unit.The clutch disc for the 4.2 should be fine if the diameter is close fit to the 240D fly wheel.IIRC,some of the Rangers did use a version of the M5R2.
awesome. I'll do some looking into it. If you find out anymore info or get your project going let me know.Thanks
cbryan0222
ben2go
Diesel Dumby
129
09-17-2010, 07:13 PM #7
(09-16-2010, 09:37 PM)cbryan0222
No problem.
ben2go
No problem.
cbryan0222
09-17-2010, 10:29 PM #8
I found a 5speed transmission today on craigslist out of a 90's models 300 six cylinder ford. I believe this is the same 5speed? And a mechanic told me today that the ford tranny was a solid transmission without a seperate bell housing. I cant find much about this.
cbryan0222
ben2go
Diesel Dumby
129
09-18-2010, 09:45 AM #9
IS there a data plate on the transmission?If there is,post up the info here.Also, http://www.4btswaps.com and http://dieselbombers.com is another good source for info.There's a section for transmissions and OM617 swaps.If I remember correctly,the 5 speed behind a 300 was a M5R2 Mazda transmission.Should be plenty strong for stock to mildly tuned OM6xx conversion.
ben2go
cbryan0222
09-18-2010, 10:53 PM #10
I am going to get the transmission on sunday and i'll post pics on here for it. Is there supposed to be a data plate on the transmission itself?
cbryan0222
ben2go
Diesel Dumby
129
09-19-2010, 11:45 AM #11
Some have a data plate,some have a metal tag,and others have numbers cast or stamped into the side.
ben2go
cbryan0222
09-21-2010, 04:44 PM #12
I went and got the transmission on sunday but i took it to a transmission shop first thing on monday to have it checked out and everything in working order. It is a M5R2. The mazda transmission that ford used behind there small block engines From 1988-now i believe and it is a solid bell housing transmission. I believe my transmission came off a 1992 ford 2wd 300 six cylinder truck that had been wrecked.
cbryan0222
ben2go
Diesel Dumby
129
09-21-2010, 04:54 PM #13
That is the most common use for the M5R2 besides the 4.2 V6.Most V8s got autos with overdrive.
ben2go
cbryan0222
09-21-2010, 08:48 PM #14
I hope it works out good. I only gave 50 dollars for the tranny but plan on putting another 2-3 hundred into it replacing the forks, slave cylinder assymbly, and throw out bearing.
cbryan0222
10-29-2010, 09:32 AM #15
so whats happening with these s10/ranger swaps? Im looking into this route as well, curious if you guys have proceeded with it or urn into any snags
ben2go
Diesel Dumby
129
10-29-2010, 10:16 PM #16
(10-29-2010, 09:32 AM)dropnosky so whats happening with these s10/ranger swaps? Im looking into this route as well, curious if you guys have proceeded with it or urn into any snags
It really depends on application.After the research I have done and the questions I have asked,It seems that a one piece trans case is going to be difficult to mate to Mercedes diesel.I still haven't found an OM617 or complete 300 in my area.The one I found cheap the guy was an @$$ hole,so I had to let it go.Here is my post on the one piece tranny case and what I decided to do.
Link to post #41 about my issue.
http://superturbodiesel.com/std/tremec-t...l#pid18102
Rudolf_Diesel had some good advice on this.
ben2go
10-29-2010, 10:58 PM #17
(10-29-2010, 10:16 PM)ben2go It really depends on application.After the research I have done and the questions I have asked,It seems that a one piece trans case is going to be difficult to mate to Mercedes diesel.I still haven't found an OM617 or complete 300 in my area.The one I found cheap the guy was an @$$ hole,so I had to let it go.Here is my post on the one piece tranny case and what I decided to do.
Finding a decent square body S10 is also a pain! I personally prefer the square body trucks. It seems that every one on craigslist has been chopped and bagged and is now a lowrider with 22" rims. I called to look at a basic 5-speed S10 long bed that was still stock, and the woman put me on a list as number 8 in line to be called if it was not sold!
Seems a ford ranger is a much more easily gotten vehicle unmodified and for cheap.
Stinks about the 300s in the area, maybe an engine off of car-part?
ben2go
Diesel Dumby
129
10-30-2010, 09:49 AM #18
Ford Rangers are a pain to lower and keep the front end geometry right.They still chew up tires on the inside.I have a 3/3 drop and I got 25,000 miles out of a 40,000 mile tire.I have two tires now that are showing threads and steel belts.Luckily it's not my daily driver.I plan to raise it back up to stock so I can get what little pay load it has back.The older Rangers have independent I beam suspension.Mine has unequal length control arms with coil springs.Rides like hell lowered.Bounces like a ping pong ball.Suspension bottoms out on the frame.The trucks like mine have a dropped transmission cross member and I drag it all the time.Sad thing is,my truck doesn't even look like it's been lowered.
This is my truck the day after I lowered it.I went from 235-70-15 tires to 215-70-15.
[Image: 1023071747.jpg]
[Image: 1023071746.jpg]
Here is my truck about two weeks before I lowered it.Can't tell a difference.
[Image: 0929071507a.jpg]
[Image: 0929071507.jpg]
[Image: 0929071506.jpg]
ben2go
10-30-2010, 10:10 AM #19
wow you are right, almost no difference over stock!
Im not really into lowering trucks, but I love the torsion bar front suspension on the nissan HB trucks, couple cranks on a bolt, you have a low rider in the front, few back, and its stock again!
Bought a HB truck for work that had been lowered, and put it back to ride height in 15 minutes with basic hand tools and a tape measure.
How does the front suspension on the S10s work?
ben2go
Diesel Dumby
129
10-30-2010, 10:55 AM #20
(10-30-2010, 10:10 AM)dropnosky wow you are right, almost no difference over stock!
All S10s have unequal length a arms up front and traditions leaf springs in the rear.An S10 is alot cheaper to lower and it's easier to maintain correct front geometry and alignment.I've done quite a few S10s.Everything from a sport drop(3-4 inches) to slammed 6+.I prefer the bolt on drop kits over the cut and weld.I have never bagged a truck but I have helped on a few.The S10 has bolt on kits for a slammed bagged ride.
ben2go
kracken
11-09-2010, 08:55 PM #21
I have a om617 bolted up to a Toyota w56.
kracken
Biohazard
Smokin like a champ!
376
11-09-2010, 10:02 PM #22
(11-09-2010, 08:55 PM)kracken I have a om617 bolted up to a Toyota w56.
You know, as far as first posts go, this one has to rank right up there. Big Grin Welcome to the forum! Care to elaborate on what all was needed to make this work? I'd love to see some pics, too!
Biohazard
kracken
11-11-2010, 02:59 AM #23
(11-09-2010, 10:02 PM)Biohazard
I will start a build thread a.s.a.p.
kracken
ben2go
Diesel Dumby
129
11-11-2010, 12:14 PM #24
(11-11-2010, 02:59 AM)kracken I will start a build thread a.s.a.p.
Thanks.
If you don't mind me asking,what Bellingham are you from?I know there's one in the UK and one in New England in the US.
This post was last modified: 11-11-2010, 12:15 PM by ben2go.
ben2go
Thanks.
mike-81-240d
more like mike-84-300d now
427
11-11-2010, 11:26 PM #25
(11-11-2010, 12:14 PM)ben2go
Thanks.
I'm guessing Washington state. Big Grin
mike-81-240d
Thanks.
ben2go
Diesel Dumby
129
11-12-2010, 10:13 AM #26
There's one in WA too?How many are there in the world.
This post was last modified: 11-12-2010, 10:14 AM by ben2go.
ben2go
cbryan0222
11-16-2010, 07:13 PM #27
I just bought a 1994 s10 off craigslist. (Not Lowered) lol bEcause they are everywhere, parts are cheap and easy to work on. They also have a little more room under the hood than rangers do. I also wanted the newer body style s10. Last week i also picked up my 5-speed transmission from the shop. There is a guy off 4btswaps.com using this ford transmission. I am still waiting on the right engine to use. i have my eye on a couple of them right now and then i'll be able to kick off my project.
cbryan0222
ben2go
Diesel Dumby
129
11-16-2010, 09:21 PM #28
Good deal.I raised our Ranger back up.Rides better but feels a lot more tippy in curves.
ben2go
eck60
05-01-2011, 09:05 PM #29
well how is s10 conversion going I am getting down to clearances on the clutch release bearing. I need .400 aprox for the release bearing to work
adapter plate is made and clutch pilot bearing and pressure plate i just need some more clearence for the release bearing to work I hope to have that worked out this week
I am selling a custom set of valve adjustment wrenches for the 0m617
this kit comes with 2 wrenches 2 feeler gauges and a instructional manual
49.99 if interested email me I take paypal
http://www.dieselbombers.com/members/dec...nches.html
eck60
 14 Guest(s)
 14 Guest(s)
