STD Tuning Engine How much power can a 300 hold
alarm92
10-17-2010, 07:00 AM #1
Hello Wink My name is Almar and I'm new on this forum. I'm a Norwegian Marine engineer, and have just bought myself a cheap and rusty 300D nonturbo w123 MB, just for fun.
The plan is simply too force more air into it (a turbo from a 6 liter ford and a extern wastegate will make sure of that, høhø) then adjust the diesel pump up.
If it works, i will use it as a driftcar at the winter (My other car i FWD -_-)
I was just wondering if anybody knows how much boost pressure i can put on this engine before i cross the red line.
The nonturbo doesn't have oil cooled pistons?
Is there someone on this forum that have converted a nonturbo into a turbo? And at last, what is the big difference between the 120 hp engine with turbo and the one with 88 hp without turbo? (crankshaft, pistons, cam shaft, valves, injectors, diesel pump? etc)
Hilsen Almar
This post was last modified: 10-17-2010, 07:42 AM by alarm92.
My English might be a bit funky, but i'm from Norway and i kind of sucked in English at school Wink
MB W123 3.0 d turbo project
Audi A4 1.8T 220hk
And a old moped
alarm92
Hilsen Almar
Audi A4 1.8T 220hk
And a old moped
10-17-2010, 07:53 AM #2
(10-17-2010, 07:00 AM)alarm92 300D nonturbo
About 88hp.
Quote:And at last, what is the big difference between the 120 hp engine with turbo and the one with 88 hp without turbo?
Everything except the cylinder head casting, valve cover and oil filter housing.
Buy this SAE paper to understand what Mercedes went through to make the engine reliable.
http://www.sae.org/technical/papers/780633
If you want more power the best option is to simply sell the car and buy a 300D turbo to start with. You'll spend a lot of money on the non-turbo engine just to get as much power and longevity will be in the toilet.
This post was last modified: 10-17-2010, 07:54 AM by ForcedInduction.
About 88hp.
JTY
10-21-2010, 06:23 PM #3
Agreed, no point to tune OM617 NA, just buy a OM617A turbo.
We have here in Finland several failed OM617 NA with added turbo and custom pump, wont handle the added thermal load for long.
Wasted money!
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
Wasted money!
alarm92
10-25-2010, 01:25 AM #4
(10-21-2010, 06:23 PM)JTY Agreed, no point to tune OM617 NA, just buy a OM617A turbo.
Wasted money!
Okay, thanks for your help, now i know what i'm looking for Smile
Audi A4 1.8T 220hk
And a old moped
alarm92
Wasted money!
Audi A4 1.8T 220hk
And a old moped
Silberpfeil
Slowly Sideways
85
10-26-2010, 02:24 AM #5
Off subject--but how far from Oslo are you??
Silberpfeil
 6 Guest(s)
 6 Guest(s)
