STD Tuning Engine Reverse rotation
Reverse rotation
Reverse rotation
yankneck696
395
01-18-2011, 07:00 AM #1
Does anyone have knowledge of an OM61X or OM60X being able to run in reverse rotation for a marine application? I would really like to replace the 318 with a Merc. Problrm is that the prop, strut, tunnel & rudder are designed for RR & the trans to reverse the rotation & stay at 1:1 costs more than a 7.5MM IP.
Application 1975 Penn Yan Avenger flybridge.
Thankyou,
Ed
yankneck696
Thankyou,
Ed
01-18-2011, 08:08 AM #2
Nope. You will need a reverser.
yankneck696
395
01-18-2011, 07:43 PM #3
Bump for anyone else? Hey Forced, I like the new graphics... How do ya do that?
yankneck696
led-panzer
01-18-2011, 08:03 PM #4
Handcuffs are not bracelets my friend Smile
1985 300D 280,000 miles RIP
led-panzer
dieselboy
Rotatin 5500 times a minute
680
01-18-2011, 09:20 PM #5
No you cannot the timing chain won't take it. The tensioner would be one the pull side of the chain and it will wear very fast and cause the chain to skip either the injection pump or cam.
The only diesels I've seen run reverse rotation are all gear driven.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
yankneck696
395
01-19-2011, 06:21 AM #6
(01-18-2011, 09:20 PM)dieselboy No you cannot the timing chain won't take it. The tensioner would be one the pull side of the chain and it will wear very fast and cause the chain to skip either the injection pump or cam.
Well, I guess that's a good enough reason. I usually work on marine diesels & they are primarily gear driven. Thanks, Jessie.
yankneck696
OM616
10mm MW
574
01-19-2011, 01:11 PM #7
Back in the day, ChrisCraft turned the engines around and used the front of the crank as the PTO, the flywheel was up front.
Now I'm not saying the OM617a is a good candidate to do that with only because I have no idea how well it would work. Just a thought to think about.
OM616
yankneck696
395
01-19-2011, 05:08 PM #8
(01-19-2011, 01:11 PM)OM616 Back in the day, ChrisCraft turned the engines around and used the front of the crank as the PTO, the flywheel was up front.
here's a real response. I'll look into that.
yankneck696
dieselboy
680
01-19-2011, 07:30 PM #9
I've seen pto drives off the front of the crank but never a transmission. There's a reason the back of the cranks are so stout. It would put alot of load on the small part of the crankshaft.
It might work for awhile but I wouldn't trust it in a boat.
What transmissionS are you running?
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
yankneck696
395
01-20-2011, 06:26 AM #10
(01-19-2011, 07:30 PM)dieselboy I've seen pto drives off the front of the crank but never a transmission. There's a reason the back of the cranks are so stout. It would put alot of load on the small part of the crankshaft.
It's a single engine with a 1:1 velvet drive.
yankneck696
Walkenvol
01-20-2011, 02:57 PM #11
Stupid question - I thought there were some props that turned CW and other that turned CCW. Can't you just get the opposite of what you currently have or will the velvet drive not operate in that direction?
Walkenvol
dieselboy
680
01-20-2011, 03:01 PM #12
Oh single? Reverse rotation prop then. On a velvet drive just turn the pump around.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
yankneck696
395
01-20-2011, 03:38 PM #13
Firstly, the tunnel drive becomes really lossy if ya use the wrong rotation unless you change strut, rudder & engine alignment
I thought changing the pump rotation is for a different engine rotation.the VD still puts out the same rotation in & out while in forward. Please correct me if I'm wrong.
yankneck696
dieselboy
680
01-20-2011, 04:30 PM #14
Oh well then your sol if your concerned about that.
What kind of boat?
I thought with the 1:1 vd when you turn the pump cover over it changes the rotation direction of the input so Fwd would still be Fwd. So you could still keep your prop rotation the same.
We junked our vd infavor of a zf so I dunno anything other than that.
This post was last modified: 01-20-2011, 04:34 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
What kind of boat?
-Jesse
70 f250 390
66 Volvo amazon
yankneck696
395
01-20-2011, 04:34 PM #15
1975 Penn Yan Avenger 23' Flybridge model.
yankneck696
dieselboy
680
01-20-2011, 05:33 PM #16
I don't know if you'd notice the reverse rotation in that big of a boat and that little power.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
casioqv
OM602 Turbo
116
01-20-2011, 07:00 PM #17
Why can't you just run the velvet drive in reverse to go forward- keeping the prop rotation the same?
This post was last modified: 01-20-2011, 07:00 PM by casioqv.
-Tyler
No mercedes (for now)
casioqv
-Tyler
dieselboy
680
01-20-2011, 09:35 PM #18
Cause they cannot hold 100% cycle duty in reverse cause it runs through a planetary in reverse.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
