STD Tuning Engine Engine Specifications
AzTraveller
Merc Convert
2
02-11-2009, 02:41 PM #1
This would be a good reference place to put the MFR specifications for the various engines used in this forum. To include MFR measurements such as Physical Length, Width, Height, Weight, HP, BHP, Idle RPM, Max RPM. Supported turbos (stock and alternatives). Supported trannys (manual and automatics). This knowledge would be extremely helpful for ALL swaps.
AzTraveller
1981300SD
02-14-2009, 12:15 AM #2
Dose anyone know what the stock turbos are?
1981300SD
02-14-2009, 04:04 AM #3
Garrett T3 from 78-85 and KKK K26 from 83-85.
There is more information here: http://www.superturbodiesel.com/std/vnt-...t-235.html
02-11-2010, 03:14 PM #4
Specs from Mercedes.
244kg= 538lbs
This post was last modified: 02-11-2010, 03:15 PM by ForcedInduction.
244kg= 538lbs
