STD Tuning Engine Find an optimal turbo
02-09-2011, 06:29 AM #1
hello guys
I'm looking for a suitable turbo for my 603
I currently have a "HX50""where I realized too late that it is not original.
This should be the data
Compressor: 86.1mm Inducer
Exducer 77mm
Turbine: 99mm inducer
Exducer 63mm
comes at 4000 rpm... that's funny that power. but too late
now I'm looking for a suitable turbo starts the past but still making performance and durability. cheap would be greatSmile
http://cgi.ebay.de/Holset-HX50-Turbolade...eile_Zubeh% C3% B6r & hash = item3364c3752b
what could be a HX35? ist it to small?
he should make 400HP
thx!
hansebanger77
hello guys
Exducer 77mm
Exducer 63mm
thx!
George3soccer
02-09-2011, 11:42 AM #2
oh i see a sls pump, what chassis is this 603 in.
400hp might be to small for a hx35, try looking for the hx40 8 blade. Should be able to reach your goal with that turbo.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
tomnik
02-09-2011, 01:47 PM #3
where did you take the turbo oil supply from??
What did you modify on your IP?
Did you use the original exhaust manifold?
Depending on what you did on the pump, I'd first try this turbo with larger element pump. Spools faster and you will need it anyway.
Tom
tomnik
Tom
02-09-2011, 02:09 PM #4
(02-09-2011, 11:42 AM)George3soccer oh i see a sls pump, what chassis is this 603 in.
w124 300d
It is a pump with a 7 mm elements of PP diesel from finland.
yes I think also a hx40 would be optimal.
but a turbo-specialists in my region, believes that the hx40 would fit, but the "wave"? "shank"? (sorry dont know the right word) is too weak. its breaking to fast at 2 bar boost pressure. now I'm not sure ...
hans
(02-09-2011, 01:47 PM)tomnik where did you take the turbo oil supply from??
Tom
Directly from the oil filter housing. with a T piece to the oil pressure switch
* 7mm elements
* Yes, unfortunately. I am not able to build myself a self. u buy? where?Huh
* The pump is enough to make diesel 400hp. the turbo spools at 4000 rpm. thus have a very narrow rpm band.Dodgy
btw the turbo has a T6 Flange and has 18kg ist verry big
thx
HansBig Grin
This post was last modified: 02-09-2011, 02:23 PM by hansebanger77.
hansebanger77
w124 300d
hans
Tom
* 7mm elements
thx
HansBig Grin
dieselboy
Rotatin 5500 times a minute
680
02-09-2011, 04:48 PM #5
Hx40 would be a good turbo to try.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-10-2011, 03:20 AM #6
ok.
there is a hx40 with t3 connection? or only t4
hansebanger77
ok.
02-10-2011, 06:30 AM #7
What about cheap turbos? has anyone already installed?
eg: http://cgi.ebay.com/ebaymotors/HX40-SUPE...ccessories
hansebanger77
dieselboy
680
02-10-2011, 12:18 PM #8
There is a hx40 with a t3 flange available. I wouldn't trust those cheap china knock offs.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-10-2011, 04:17 PM #9
I like the adapter though...
majesty78
02-10-2011, 11:54 PM #10
Hallo Hans, liebe grüße aus der Nähe von Wien; -)
lg alex
majesty78
lg alex
02-11-2011, 03:43 AM #11
hallo alex Smile kennen wir uns? Smile
who knows someone selling one hx40 flange with T3?
the Holset seller in Austria will assemble with a 16cm housing (too large?) and a compressor side with a large bandwidth and a wastgate. but can cost up to 850 €. is this normal?
He says there are 100 varieties of hx40.
ebay is an original (no china crap) for € 477.?
but I think the shipping is expensive. and slow.?
omg are these procedures.
I will only buy a single turbo, which should fit ...
hansebanger77
02-24-2011, 07:35 AM #12
(02-10-2011, 12:18 PM)dieselboy There is a hx40 with a t3 flange available. I wouldn't trust those cheap china knock offs.
thx this is my new oneHeart
hansebanger77
majesty78
02-24-2011, 09:29 AM #13
TurboTwins made you happy?
As this Turbo is a twin scroll, you might be interessted in a performance manifold for twin scroll design turbine housings like made from kkd performance. ...
Regards, Alex
This post was last modified: 02-24-2011, 09:33 AM by majesty78.
majesty78
Regards, Alex
02-24-2011, 06:32 PM #14
(02-09-2011, 06:29 AM)hansebanger77 This should be the data
Not quite.
Compressor
63mm Inducer
99mm Exducer
Turbine
86.1mm Inducer
77mm Exducer
HX35 would be fine for that. HX40 would work but still be very slow to spool.
Not quite.
Compressor
63mm Inducer
99mm Exducer
Turbine
86.1mm Inducer
77mm Exducer
02-25-2011, 02:50 AM #15
turbo is fit good with the t3.
the turbine housing is the smalest he coud get for the hx40. testdrive: spool at 3000rpm verry fast. its nice to drive.
if someone could tell me now, what can I take for single mass flywheel'?? ...in another thread of me...
that I can customize a proper clutch. to get the power on the weels
I can finally be upload a video where the rear axle begging for help
hansebanger77
dieselboy
680
02-25-2011, 03:11 AM #16
You got it installed?! Video please!!
I have no knowledge on the flywheels sorry.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
Bangaway
606 Turbo > Porsche Turbo
129
01-15-2013, 08:09 PM #17
Hansebanger--I need to get a turbo. Your turbo works great so...I'll copy you if you don't mind! and get something similar. As you know, the Holset HX40W comes in many variations. Do you know the exact specifications of you turbo setup?
-how many blades?
-60mm or 56mm?
-16cm?
-T3?
Do you have the exact Holset part number?
How about your KKD manifold...did they do anything special with it? Thanks...More videos please haha
This post was last modified: 01-15-2013, 08:14 PM by Bangaway.
Bangaway
-how many blades?
-60mm or 56mm?
-16cm?
-T3?
 11 Guest(s)
 11 Guest(s)
