Can I adjust the idle higher on a w116 300sd?
i just wanted to know if it was possible to adjust the idle slightly higher on a w116 300sd turbo diesel om617.
thanks
where exaclty is that nut? im going to check first thing tommorrow morning and adjust.
any diagram or picture of the IP and location of idle adjustment?
thanks guys
(02-24-2011, 02:05 PM)winmutt Just look with a light. its like a 1" long nut.
Its on the engine side of the injection pump. 14mm lock nut and flatblade screwdriver to adjust. Do not over tighten or you can break off the mount like on this pump.
(02-24-2011, 04:05 PM)Captain America(02-24-2011, 02:05 PM)winmutt Just look with a light. its like a 1" long nut.
You talking about the rack damper?
(02-24-2011, 06:23 PM)W116Lorinser(02-24-2011, 04:05 PM)Captain America(02-24-2011, 02:05 PM)winmutt Just look with a light. its like a 1" long nut.
Someone confirm all this please before i start touching the IP which is something i dont wanna mess with.
