STD Maintenance General Can I adjust the idle higher on a w116 300sd?
W116Lorinser
OM617.95
147
02-23-2011, 02:03 PM #1
i just wanted to know if it was possible to adjust the idle slightly higher on a w116 300sd turbo diesel om617.
thanks
W116Lorinser
thanks
02-23-2011, 05:39 PM #2
Yes. There is a long nut looking thing on the IP.
W116Lorinser
OM617.95
147
02-24-2011, 12:01 AM #3
where exaclty is that nut? im going to check first thing tommorrow morning and adjust.
any diagram or picture of the IP and location of idle adjustment?
thanks guysSmile
W116Lorinser
thanks guysSmile
02-24-2011, 02:05 PM #4
Just look with a light. its like a 1" long nut.
02-24-2011, 04:05 PM #5
(02-24-2011, 02:05 PM)winmutt Just look with a light. its like a 1" long nut.
You talking about the rack damper?
02-24-2011, 06:22 PM #6
Its on the engine side of the injection pump. 14mm lock nut and flatblade screwdriver to adjust. Do not over tighten or you can break off the mount like on this pump.
W116Lorinser
OM617.95
147
02-24-2011, 06:23 PM #7
(02-24-2011, 04:05 PM)Captain America
Someone confirm all this please before i start touching the IP which is something i dont wanna mess with.
W116Lorinser
02-26-2011, 12:55 PM #8
(02-24-2011, 06:23 PM)W116Lorinser
Forced showed you in the picture, its the same piece. Except in the picture its just broken off.
This post was last modified: 02-26-2011, 12:56 PM by garage.
