STD Tuning Engine fuelpump om606 300td
johan84
03-08-2011, 11:26 AM #1
hello
i'm new at this forum i have read a lot but now made my account
i'm from holland
i have a daily driver w123 petrol on lpg
i thinking of buying a diesel much more fun high torque
and higher mpg
but i have read a lot about the om606 24v tuning
i have a question about the fuelpump
when the engine is tuned to run with a bigger turbo and higher pressure
is a myna pump always needed or can also the element just be changed
from 5mm to 7mm?
can the injectors be standard als when going to 400hp?
what is the best to use a ecu controled fuelpump or the older fuelpump
full mechanical ?
and are the electronic's on the market to reprogram the new need fuel delivery?
i now a lot of question i have collected themBig Grin
This post was last modified: 03-08-2011, 11:28 AM by johan84.
johan84
hello
i'm from holland
and higher mpg
from 5mm to 7mm?
full mechanical ?
johan84
03-09-2011, 11:12 AM #2
nobody?
did i do somehing wrong?
did i overlooked something
Huh
johan84
nobody?
Huh
03-09-2011, 09:29 PM #3
I think someone mentioned this recently. It certainly is possible to upgrade the electronic pump, it's just that it's not done. Presumably because mechanical is easier to adjust.
There is no aftermarket electronics. You will have to figure out the electronics yourself or have someone figure it out. That is most likely the reason people don't use the electronic pump.
johan84
03-10-2011, 02:54 AM #4
oke so a fuelpump of a om603 is used instead
i will have a look at the electronics
and will use the seach engine betterRolleyes
johan84
