STD Tuning Engine decision time - oil coolers necessary?
mr_manny
Diesel Offroad Club
91
03-23-2011, 05:41 PM #1
currently working on oil-lines, and have started wondering if the stock oil-cooler is really necessary?
Other then reduced oil capacity...are there any other issues I may encounter in a non-autobahn continent?
thanks,
manny
[Image: IMG954845.jpg]
[Image: IMG954474.jpg]
mr_manny
thanks,
manny
03-23-2011, 06:12 PM #2
There were factory euro 240d's that didn't come with it.
yankneck696
395
03-23-2011, 06:53 PM #3
With the turbo, I would keep it. Cheap insurance for a pricey project you have there.
Ed
yankneck696
Ed
03-23-2011, 08:26 PM #4
(03-23-2011, 05:41 PM)mr_manny currently working on oil-lines, and have started wondering if the stock oil-cooler is really necessary?
Absolutely. Oil is the primary cooling medium of the engine's pistons and lower half.
JTY
03-26-2011, 06:00 PM #5
No doubt you need oil cooler, the bigger the better and please use cooler with thermostat
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
300D50
Graphite Moderator, ala RBMK
03-26-2011, 10:23 PM #6
Cool oil keeps your pistons happy. Wink
300D50
03-26-2011, 10:28 PM #7
and turbo happy!
and turbo happy!
03-28-2011, 02:35 AM #8
The oil needs to be over 100*c to boil out moisture.
03-28-2011, 03:33 PM #9
(03-28-2011, 02:35 AM)ForcedInduction The oil needs to be over 100*c to boil out moisture.
I can attribute to that!
On that note... My 300 with the toasted head gasket (and hydro-locking #2 cylinder) One time after I cranked the water out of the glowplug hole and got her started, I went to get some lunch with a buddy. Pulled up to Jack in your ass and left the car running right in front of the door. CCV hose went straight to the ground and had a jet of steam (5/8" hose) coming out of it.... Some black lady said something like "Why is that car steaming so much?" My buddy replied with "Oh, that car is hydrogen powered..." She believed him!
This post was last modified: 03-28-2011, 03:34 PM by Captain America.
03-28-2011, 07:20 PM #10
Yeah, I get "whats that hose" quite a bit. I think the looks are worth it to keep oil out of the intake.
This post was last modified: 03-28-2011, 07:21 PM by ForcedInduction.
03-29-2011, 01:56 AM #11
Ahhh yes. With mine, I routed it to the drivers side between the lines right at the PS box and loosely secured it to the brake rod. It doesn't hang quite as low as yours
This post was last modified: 03-29-2011, 02:00 AM by Captain America.
dieselboy
Rotatin 5500 times a minute
680
03-29-2011, 02:19 AM #12
Mines on the drivers side down low too but I hardly ever get anything out of it.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
mr_manny
Diesel Offroad Club
91
03-29-2011, 03:40 PM #13
Deleting the oil-cooler to provide for a Cleaner Install and eliminate potential oil leaks associated with lines/oil-cooler in the future.
vs
Benefits with turbo/motor longevity gained from the oil-cooler.
keeping the cooler Smile
thanks for the replies...
mr_manny
vs
mr_manny
Diesel Offroad Club
91
04-03-2011, 05:40 PM #14
oil cooler is back Smile
[Image: oil-01.jpg]
[Image: oil-02.jpg]
decided to run one of these from Earl's:
http://www.summitracing.com/parts/EAR-81610ERL
Oil Thermostat and some line routing/cleaning are all that remain for this issue Smile
mr_manny
[Image: oil-01.jpg]
[Image: oil-02.jpg]
4rnnr33
04-04-2011, 02:03 AM #15
(04-03-2011, 05:40 PM)mr_manny oil cooler is back Smile
[Image: oil-01.jpg]
[Image: oil-02.jpg]
where did you get the remote filter bracket (engine side) or is that a custom part? Im looking into doing the remote mount setup yours looks super clean
4rnnr33
[Image: oil-01.jpg]
[Image: oil-02.jpg]
04-04-2011, 07:30 AM #16
you mean this part?
http://www.superturbodiesel.com/std/thre...ion-plates
you mean this part?
mr_manny
Diesel Offroad Club
91
04-04-2011, 08:39 AM #17
made the adapter out of 1/2 aluminum:
http://www.superturbodiesel.com/std/thre...8#pid22268
@$25 I would have purchased one from 300D50...if they were available :p
mr_manny
4rnnr33
04-04-2011, 03:10 PM #18
Yep thats exactly what I needed thanks
What are you guys running for a thermostat just trying to decide which one to get
This post was last modified: 04-04-2011, 04:07 PM by 4rnnr33.
4rnnr33
mr_manny
Diesel Offroad Club
91
04-05-2011, 10:49 AM #19
(04-04-2011, 03:10 PM)4rnnr33 Yep thats exactly what I needed thanks
I'm going to be running this one:
[Image: 25011_126_detail.jpg]
This Billet Style Cast Aluminum Fluid Control Thermostat with 1/2” NPT ports allows the oil to bypass the cooler until it reaches 180°F at which point the internal thermostatic valve closes allowing 95% of the oil through the cooler. This process allows the engine/transmission to achieve the ideal operating temperature quicker before passing the oil through the cooler. At temps below 180°F the valve is open, with 90% of the oil bypassing the cooler. The remaining 10% of the oil flows through the cooler, maintaining constant system pressure, preventing air pockets and eliminating cold oil shock.
The unit can be rotated 180° to change flow direction.
Perfrect for all-season climates
Flow: 20 gpm
Rated to 200 psi
mr_manny
Flow: 20 gpm
Rated to 200 psi
300D50
04-05-2011, 01:14 PM #20
I'd get a ~210 deg version, so the water can cook out.
300D50
4rnnr33
04-05-2011, 03:04 PM #21
(04-05-2011, 01:14 PM)300D50 I'd get a ~210 deg version, so the water can cook out.
Is there one available for a decent price? The only one Ive seen so far is the canton racing which is about $170 on summit and looks pretty overkill for what Im doing.
4rnnr33
300D50
04-05-2011, 03:08 PM #22
Haven't looked, I'll try and find the spec for the stock one.
300D50
04-05-2011, 03:48 PM #23
Cooking water is a must!
4rnnr33
04-06-2011, 03:54 PM #24
The stock one must be around 180 because my oil temp gauge will barely hit 180 even after its plenty warmed up. Unless my stock thermostat isnt working properly?
(04-05-2011, 03:08 PM)300D50 Haven't looked, I'll try and find the spec for the stock one.
4rnnr33
300D50
04-06-2011, 05:56 PM #25
Then I'd say go for it! Big Grin
300D50
 16 Guest(s)
 16 Guest(s)
