STD Tuning Suspension Request for pictures of your lowered w123
07-31-2009, 03:11 PM #1
Couple days ago I decided to cut my front springs. The rear of the car is kind of low already so I decided to kind of even things up. But I think I took too much off. I chopped out 1.5 coils.
With 205 70 R14 tires, the top of the tire is about a "visual" 1/2 inch below the fender opening/lip.
I think it is kind of low for me... But before I get another set of springs to cut or possibly use the 240D/280E springs, who else has lowered their cars and do you have pictures of it along with the specs of the springs you used?
Thanks.. But I probably will end up keeping it the way it is....
This post was last modified: 07-31-2009, 03:33 PM by DeliveryValve.
07-31-2009, 05:22 PM #2
Your tires are to small thats all.
[Image: 2009_0613_cohutta_wma_0604.JPG]
holmz88
'82 300DT
8
07-31-2009, 05:32 PM #3
What size tires do you recommend?? What's the largest tire that will fit??
holmz88
07-31-2009, 06:08 PM #4
(07-31-2009, 05:22 PM)winmutt Your tires are to small thats all....
What? It's bigger then the stock size. 24.7 inch circumference for the stock 195 70 R14 vs 25.3 for the 205 70 R14. These are balloon tires!
Anyways I am looking to get some 15s or 16s a bit later.
What size are you running?
SurfRodder
Jackass Extraordinaire
611
08-01-2009, 02:00 AM #5
I run 225/50 16" on mine, the front looks pretty much like yours... I was worried about clearance at first, but after turning it lock to lock, there was plenty of clearance all the way around, so I am not too worried about it. I know plenty of others have had good luck running 215/55 16" though, so if you're worried about clearance at all, that might be the better way to go.
on second look at your pic, I really like the way that thing is sitting, mine is still way too low in the rear and I will be following Greasy's SLS removal thread w/great interest...If I can get it to ride that much higher, I could leave my heavy ass toolbox in the trunk and have no issues.
OBK# 62
SurfRodder
OBK# 62
GileadGarage
08-24-2009, 05:36 PM #6
My TD after 1 coil from front, 215/50/16's, 5 MM spacers o I could use my stock lugs.
Next time I'd prbably go w/55's or the 225/50's since there is plenty of room around the 215/60's
I have no nubs on my front shims, I guess these are the lowest avail.
Car rides nice, but not as squishy as the 240 on the rough stuff
[Image: 010.jpg]
<a href="http://s156.photobucket.com/albums/t13/markp-svoimages/?action=view&current=010.jpg" target="_blank"><img src="http://i156.photobucket.com/albums/t13/markp-svoimages/010.jpg" border="0" alt="Photobucket"></a>
This post was last modified: 08-24-2009, 05:36 PM by GileadGarage.
GileadGarage
[Image: 010.jpg]
10-02-2009, 06:59 PM #7
Here is an update. I decided of going with 1 coil lopped off. 1 1/2 coil cut makes the car a bit too low for my taste. I tried to keep it there, but in the end it bothered me too much.
The first pic is the car in stock configuration - Notice fender to wheel gap.
Second pic is with 1 1/2 coils cut from the front springs - Thought it was too low.
Third pic is 1 coil cut from the front spring in addition with different wheels. (I didn't take a good pic with the original bunts)
Fourth pic are the spring cuts. First round 1 1/2 coils cut, Second round 1 coil cut. (I gave 1 1/2 coil cut springs to 606Power. Hopefully he'll post up pics of his ride with them.)
Fifth pic are the two cut springs compared to the stock.
I have the 1 nub stock pads on my springs
(see pics 6-8)
This post was last modified: 10-02-2009, 07:02 PM by DeliveryValve.
(see pics 6-8)
SurfRodder
611
10-04-2009, 04:50 PM #8
looks good man!
OBK# 62
SurfRodder
looks good man!
OBK# 62
charmalu
10-16-2009, 11:24 PM #9
I hope this attachment works.
Ok I installed 240D front springs with the one nub pads the 300D had. since I did the 4-speed swap the nose was riding way too high. made the front end wander at higher speeds, especially with 4 people.
with the front end high it threw out the geometry of the syspention.
Charlie
think I have theis picture posting worked out.
Here are the rest.
The 240 springs dropped the front down 1 1/2 inches from where it was.
the ride is a little softer now, and in a tight left turn, (50 mph) on a mountain road, the right corner drops more than it use to, and vice versa. over all it handles ok.
I just pulled a TD front sway bar that is going in next.
Charlie
This post was last modified: 10-16-2009, 11:38 PM by charmalu.
charmalu
Charlie
Here are the rest.
Charlie
charmalu
10-17-2009, 12:43 AM #10
The one nub is the 300D, 3 nub 240D.
The longer spring on the right is the 240.
Charlie
This post was last modified: 10-17-2009, 12:50 AM by charmalu.
charmalu
Charlie
10-17-2009, 03:42 AM #11
Looks good Charlie, the 240 springs did the trick. What size tires are you running?
charmalu
10-17-2009, 05:02 AM #12
(10-17-2009, 03:42 AM)DeliveryValve Looks good Charlie, the 240 springs did the trick. What size tires are you running?
There 205-70-14 Legacy from Big-O. this is the second set of them.
last set I replaced 2 @ 73,xxx miles and one @ 75,xxx miles. Had one replaced from a piece of metal I ran over.
Charlie
charmalu
Charlie
charmalu
10-20-2009, 03:24 AM #13
    This from over on Peach Parts. some of you might remembr this car, OLBRENNER had it, since sold it and moved on to bigger and better things. and hasn`t posted in a year.
This thread is "Verdict Cutting Springs" and a few mor pictures of the car and what he did to the radical drop.
www.peachparts.com/shopforum/showthread.php?t=222645
Charlie
This post was last modified: 10-20-2009, 10:51 PM by charmalu.
charmalu
Charlie
03-17-2011, 11:27 AM #14
Just remember, too much drop == not enough travel == shitty DD.
03-17-2011, 03:13 PM #15
I would disagree, Especially when you look at a trophy truck! Tongue
dieselboy
Rotatin 5500 times a minute
680
03-17-2011, 03:50 PM #16
I think he's saying by going to low you will loose your uptravel and it will ride like crap because it will hit the bumpstops all the time.
I really like how my setup is. I'll make it up your way one day and take you for a ride.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
03-17-2011, 06:14 PM #17
(03-17-2011, 03:50 PM)dieselboy I think he's saying by going to low you will loose your uptravel and it will ride like crap because it will hit the bumpstops all the time.
db where's your pictures. w116s and others are allowed! Smile
03-17-2011, 06:54 PM #18
This.
This.
dieselboy
680
03-17-2011, 07:26 PM #19
ill take some more tomorrow. Im driving 350miles to San Louis Obispo so ill clean it all up and take some.
old pics
[Image: 52ec11a5.jpg]
[Image: d3751af5.jpg]
[Image: 8220e639.jpg]
to low at first lol
[Image: 9b3855f9.jpg]
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
old pics
to low at first lol
-Jesse
70 f250 390
66 Volvo amazon
03-17-2011, 09:50 PM #20
Air bump or progressive bumpstops!
Not the best shot, But I cut 2 coils and it rides/handles fantastic
03-24-2011, 07:03 PM #21
(03-17-2011, 09:50 PM)Captain America Air bump or progressive bumpstops!
Thats what im talkin bout, air bumps on these cars would make the ride AMAZING
tantank79
T3-45
109
03-30-2011, 08:38 AM #22
[Image: DSC_0050.JPG]
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
03-30-2011, 11:04 AM #23
Speaking of riding on bumps ^^^^^
03-30-2011, 12:57 PM #24
(03-30-2011, 08:38 AM)tantank79 [Image: DSC_0050.JPG]
That picture kicks assCool
Can we have more???
Do you autocross often?
Can we have more???
tantank79
T3-45
109
03-30-2011, 02:12 PM #25
(03-30-2011, 11:04 AM)winmutt Speaking of riding on bumps ^^^^^
It's veeerry close but not continously on the bumps there.
More? Certainly! The whole set can be found here:
https://picasaweb.google.com/dennis.wittekind/Autox3s11#
[Image: DSC_0053.JPG]
[Image: DSC_0036.JPG]
[Image: DSC_0056.JPG]
I've autocrossed this car about 10 times over the past two years. It can perform suprisingly well.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
Lowdown89
05-04-2011, 04:24 AM #26
Diesel boy, in that bottom picture how many coils are cut? I'm looking to get my 300d as low as possible with just cutting the springs, and I really like the way yours looks....
Lowdown89
Joe Reitman
06-04-2011, 11:50 AM #27
1.5 coils cut in front, photo in signature
John 3:16; John 14:6
'83 300CD 115,XXX miles lowered
'06 Dodge 3500 Cummins modded
'82 Yamaha 465 Enduro Street Legal
[Image: IMG_1047.jpg]
Joe Reitman
RonB
06-11-2011, 06:41 AM #28
[Image: image59163.jpg]
[Image: _10100023xhe.jpg]
RonB
06-15-2011, 12:38 AM #29
WOW. That wagon is BEAUTIFUL!
06-15-2011, 08:34 PM #30
(06-15-2011, 12:38 AM)Captain America WOW. That wagon is BEAUTIFUL!
^^^ Indeed a Beautiful car!
dieselboy
680
06-16-2011, 12:55 AM #31
Where did they get the smooth grill?
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
RonB
06-16-2011, 01:56 AM #32
[quote='dieselboy
[/quote]
I have seen a few of these In germany,they weld up the star mount hole and rechrome the shell.
here is a Brabus W123
[Image: brabus242.jpg]
RonB
[quote='dieselboy
[/quote]
randomdude
08-02-2011, 02:02 PM #33
RonB, where did you get the body kit on the first 4dr? not the brabus, the one in your first post.
cars? what cars? WHERE???
randomdude
Oil Burner
Turbo Everyting!!!
83
08-02-2011, 06:10 PM #34
(08-02-2011, 02:02 PM)randomdude RonB, where did you get the body kit on the first 4dr? not the brabus, the one in your first post.
I want to know also... Do they make it for the CD
Oil Burner
08-02-2011, 08:33 PM #35
I doubt thats his.
I doubt thats his.
randomdude
08-03-2011, 01:52 PM #36
does anyone know where to get a mild kit close to that?
randomdude
08-08-2011, 04:16 PM #37
There is a guy in the Philippines who sells AMG copies. No matter what your talking ~$400-600 shipped.
 19 Guest(s)
 19 Guest(s)
