STD Tuning Engine Bigger turbo, bigger elements, FMIC...what else?
civicious
04-05-2011, 05:54 PM #1
Hi everyone, I'm Wil. I'm a tech at a shop that does performance and maintenance on high-end/exotic cars (Ferrari, Lamborghini, Porsche, Mercedes). I know a good bit about gasoline-powered vehicles, but not a whole lot about diesel. I do own a Dodge 3500 diesel, but everything that I've done to it has been essentially bolt-on, and didn't require any special know how (programmer, exhaust, intake).
I've recently purchased an 85 300D as a project car, of sorts. It's got around 304k on it, and with the exception of a leaky oil pan gasket and some clackedy valves, it runs (relatively) excellent. The A/C doesn't work, but other than that everything in the car is fucntional.
I know from reading around on here that there is some power to be made by turning up the injection pump and swapping out the elements. If I put a bigger turbo on, turn up the fuel, and intercool it, I should be able to get a good bit more power out of it, at least in my mind...
Is there any input or advice that someone can chime in with regarding this?
Thanks in advance, guys!
-wil
civicious
-wil
04-05-2011, 06:02 PM #2
More fuel+More air=POWER
Thats basicly the deal with diesels. haha.
Your plan sounds good to me!
polarisrmk
603 95' 124 WAGON
78
04-05-2011, 07:16 PM #3
Get out your pocket book. The pump mods are not cheap.
polarisrmk
civicious
04-05-2011, 07:30 PM #4
Other than the elements, what pump mods are necessary?
civicious
04-05-2011, 07:36 PM #5
Good question!
As far as i know, none.
Good question!
civicious
04-05-2011, 07:42 PM #6
Where's the 'not cheap' part? lol
civicious
04-05-2011, 07:53 PM #7
(04-05-2011, 07:30 PM)civicious Other than the elements, what pump mods are necessary?
http://www.superturbodiesel.com/std/thre...er-install
04-05-2011, 07:57 PM #8
The elements, and the installing of the elements(correctly).
Bosch elements cost $2-300 each i belive, the elements that we are buying on that "8mm element" thread are of unknown quality. Were hopeing that they work correctly.
Another $$$factor is finding a shop to install them correctly.
Before Delivery Valve contact this diesel shop in Bakersfield, the only option this site knew of was Myna in finland. And a couple members themselves, but the have stopped showing up here recently.
civicious
04-05-2011, 08:33 PM #9
I've built twin turbo Gallardos, fabricated 200+mph 911's, and dozens of 500+whp Mercedes's of various models...some injection pump elements shouldn't be a big deal.
civicious
polarisrmk
603 95' 124 WAGON
78
04-05-2011, 08:35 PM #10
Do some more reading on this forum. Mods can cost up to $2000 for elements and DV's properly installed, pump put on a test bench and adjusted properly. the valves themselves are not cheap either as was mentioned. Its not as simple as putting the elements in.
Once your pump is giving you more fuel then you run into even more expenses. Turbo, Intercooler, gauges, plumbing. Not to mention at 300k your car is probably due for a timing chain, injector rebuild/balance, complete front suspension rebuild, vacuum pump rebuild, the list can go on and on for some people depending on the care the previous owner took of the car.
As many smart people have annoyingly said over and over on this forum. Modifications should only be done if the engine and all of its components are in order. Do some more research before you leap. These cars are German and Germans never do anything simpleSmile
polarisrmk
civicious
04-05-2011, 08:39 PM #11
100% of the suspension is brand new, as is the vacuum system. Also has a brand new gearbox, and is going to get all new internals (as needed) when the motor gets built. Fabbing up an intercooler, manifolds, and piping is no big deal either.
I just want to make sure I'm not missing any essential components.
civicious
polarisrmk
603 95' 124 WAGON
78
04-05-2011, 08:45 PM #12
(04-05-2011, 08:33 PM)civicious I've built twin turbo Gallardos, fabricated 200+mph 911's, and dozens of 500+whp Mercedes's of various models...some injection pump elements shouldn't be a big deal.
There are only a few select people in this world that can properly tune one of these injection pumps. If it was that simple every person on here would just go to their local diesel shop that has a test bench and "git r dun". From what I gather there are mostly problems with getting the engine to idle properly with the larger elements and the pump adding fuel linearly with boost. If you think you can do it, try it i am sure there will be people here banging down your doors to have you do their pumps.
polarisrmk
04-05-2011, 08:46 PM #13
polarisrmk covered it all.
04-05-2011, 10:50 PM #14
If its not such a big deal, then PLEASE tune up one of these pumps for some serious power and let us know how it goes.
Im sure we would all appreciate it.
Motorhead
04-06-2011, 12:44 AM #15
I build supercar engines and one of them holds the record for the fastest standing mile in the world @ 266 MPH but I know my place when it comes to diesel tunning, if you find somthing out about the I/P elements please share it with us.
Motorhead
dieselboy
Rotatin 5500 times a minute
680
04-06-2011, 01:00 AM #16
I haven't seen another fmic other than my car so far, and mine isn't a w123
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
civicious
04-06-2011, 07:18 AM #17
(04-05-2011, 10:50 PM)garage
That's what I'm working on, as soon as this group buy on the 8mm elements comes through.
(04-06-2011, 12:44 AM)Motorhead
You work for Heffner? I thought he was in Florida?
(04-06-2011, 01:00 AM)dieselboy I haven't seen another fmic other than my car so far, and mine isn't a w123
Really? I figured anyone trying to make power on these would have put on an fmic...it's not like you need a condenser up there anyways, lol. Any particular reason noone runs intercoolers?
civicious
dieselboy
680
04-06-2011, 09:32 AM #18
No room.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
No room.
-Jesse
70 f250 390
66 Volvo amazon
civicious
04-06-2011, 10:02 AM #19
(04-06-2011, 09:32 AM)dieselboy No room.
[Image: 28611d1294831454-heating-pipe-sawzall.jpg]
civicious
300SD_KY
super turbo diesel
121
04-06-2011, 11:24 AM #20
Check out Teemu's page www.blacksmokeracing.com
He is also high po diesel krazy.
Finnish drifting diesel wagon.
Keep posting!
Interested in following your build.
300SD_KY
Keep posting!
civicious
04-06-2011, 11:52 AM #21
(04-06-2011, 11:24 AM)300SD_KY Check out Teemu's page www.blacksmokeracing.com
Keep posting!
Already been all over it...he's running an OM606 though. I do plan on running a VERY similar i/c and turbo setup as him though. I'm also going to (more than likely) retain an automatic transmission.
civicious
Keep posting!
Motorhead
04-06-2011, 01:22 PM #22
(04-06-2011, 07:18 AM)civicious
We built the engine on that project for Heffner, Accufab Racing is in California. Heffner built the car.
This post was last modified: 04-06-2011, 04:58 PM by Motorhead.
Motorhead
jeemu
457
04-07-2011, 01:50 PM #23
Have not to be a wisard to build 400hp om606, but what is that? Its just 400hp engine hundreds among Big Grin
This post was last modified: 04-07-2011, 01:53 PM by jeemu.
jeemu
 13 Guest(s)
 13 Guest(s)
