STD Other FS / WTB / Buying guides WTB 300GD flywheel
WTB 300GD flywheel
WTB 300GD flywheel
Syncro_G
0-60 in 29 sec
280
03-30-2011, 06:40 PM #1
Hi, I'd like to get a 300GD flywheel and would like to source one stateside before plopping a chunk of change to ship one from Germany.
I happen to have a 240GD flywheel as partial trade. Like the 300GD FW, it has a 230mm clutch surface but is light like the 240D FW. I haven't seen the proper specs for it but it's likely near or possibly below wear limits. No good for a heavy G-wagen but probably still lots of fun for an STD sedan.
-Christian
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
-Christian
'75 240D 4-Speed
04-01-2011, 07:54 AM #2
Oh that 240GD would be a hot swap for a super 617. I paid ~600 for my 300gd FW from classic parts NIB.
Syncro_G
0-60 in 29 sec
280
04-05-2011, 09:26 AM #3
(04-01-2011, 07:54 AM)winmutt Oh that 240GD would be a hot swap for a super 617. I paid ~600 for my 300gd FW from classic parts NIB.
I just did the same. ~$600 new and delivered from Euro-Truck. I found a couple used in Germany but shipping costs pushed their prices over $500.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
04-06-2011, 09:20 AM #4
Is the clutch and pressure plate the same as the 204GD and 300GD? I might be interested in that 240gd fw of yours.
Syncro_G
0-60 in 29 sec
280
04-07-2011, 02:19 AM #5
(04-06-2011, 09:20 AM)winmutt Is the clutch and pressure plate the same as the 204GD and 300GD? I might be interested in that 240gd fw of yours.
Clutch surface is 230mm across. My 300GD clutch kit fits nicely on it.
However, one of the G wagen guys expressed interest earlier. I'll PM you if he passes on it.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
BRABUS
04-07-2011, 07:44 AM #6
(04-07-2011, 02:19 AM)Syncro_G
Will a 240gd/240d 300gd flywheel with clutch and pressureplate bolt right on the 617a ? ifso will 240gd/300gd or 240d manual transmission fit on the engine then?
Sorry for stealing your postSmile
BRABUS
04-07-2011, 08:18 AM #7
(04-07-2011, 07:44 AM)BRABUS
I am using the 300GD FW in my car with manual trans from 240d.
http://www.superturbodiesel.com/images/b...20upgrade/
[Image: Rolf%20019.jpg]
If anyone goes with a 300GD FW on a W123 I recommend splitting the difference in weight at the machine shop. My off the line torque increased and my top end HP decreased.
BRABUS
04-07-2011, 08:49 AM #8
Okei. Nice Smile will i need to Balance the crank and flywheel?
BRABUS
04-07-2011, 08:55 AM #9
I did not. Your mileage may vary.
SurfRodder
Jackass Extraordinaire
611
11-06-2011, 04:48 PM #10
not to drag up an old thread, but I finally installed my 300GD setup as well and I definitely recommend balancing the new setup.
Mine was significantly out of balance as well as the pressure plate so I had them both balanced and then balanced as a set. I did not bother doing it with the old 240D flywheel/PP I had and there was significant vibration at certain engine RPM.
Some of that is likely due to the larger mass being a bit more forgiving, but I figure paying that much for the flywheel you might as well do it the best you can. I paid about 130 bux to get mine balanced the way it is, but I don't know if thats a good price or not. I do know that the thing is much smoother that it ever was before. I likely would have balanced the 240D setup as well, but I never intended to leave it in as long as it was.
The car is also not as quick as it used to be, but a lot easier to start out uphill than it used to be and does not buck like the old setup did (it used to act like it was being lugged, even in 1st gear most noticeably in traffic or low speed cruising, like parking lots and a lot of clutching was necessary, now it is totally a smooth drive). Anyway, well worth the effort. Now, to make more power...
note: my auto flywheel was neutral from the factory, so "match balancing" was simply a matter of getting the 300GD setup dialed in neutral as well...
This post was last modified: 11-06-2011, 04:51 PM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
