STD Other FS / WTB / Buying guides fs springs
fs springs
fs springs
04-25-2011, 11:25 PM #1
Ok, got the front springs out. Dunno how to get the rear ones out, the spring compressor I borrowed couldn't fit in there. But maybe I can get them out when I chop through the frame Wink
Also, I wonder how in the h#ll you're supposed to work that compressor. Even after I compressed the springs I still needed to take apart the upper control arm to get the mf out of there.
oh and a power steering pump too.
This post was last modified: 04-25-2011, 11:36 PM by larsalan.
04-26-2011, 12:50 AM #2
Ummmm, I just use a big crowbar.....
Like this!
http://www.sears.com/shc/s/p_10153_12605...P?prdNo=21
Makes for some excitment
Like this!
mike-81-240d
more like mike-84-300d now
427
04-26-2011, 03:52 PM #3
How much shipped to 98033? Don't really wanna chop the stockers. Fronts only.
mike-81-240d
04-26-2011, 04:15 PM #4
They are about 30lbs and 18in long. Would you look into the shipping and we could figure a price? There's some rust on there but would brush off with a flap disc.
I'll try and get the backs off too.
[Image: IMG_0315.jpg]
This post was last modified: 04-26-2011, 04:16 PM by larsalan.
mike-81-240d
427
04-26-2011, 04:32 PM #5
Damn... Not short enough for a flate rate box.
mike-81-240d
04-26-2011, 04:54 PM #6
usps about 50
ups about 40
fedex about 35
That's all from their online estimators. Wanna pay 50 on top of the shipping?
usps about 50
ups about 40
fedex about 35
mike-81-240d
427
04-26-2011, 05:03 PM #7
holy shit... Lemme check my H&R sources first Wink
mike-81-240d
04-27-2011, 08:35 AM #8
Did you use the plate compressor? You want to rotate the plates all the way to the top and bottom.
04-27-2011, 08:49 AM #9
Plate compressor? I just borrowed a strut spring compressor from the autopart store
[Image: SpringCompressor.jpg]
How can I get the back springs out? The bolts on that one I borrowed were way too long to fit in the area.
Biohazard
Smokin like a champ!
376
04-27-2011, 09:24 AM #10
I've pulled the rear springs several times now. The easy way is remove the shocks, remove swaybar links, loosen the subframe mounting bolts about 1/2 inch. Put a jack under the rear diff and then unbolt the rear diff mount. Lower the rear end down and the springs just fall right out!
Biohazard
04-27-2011, 03:21 PM #11
Ok, I'll try that. If it ever stops raining and I can get a day off work.
05-09-2011, 02:16 PM #12
Now have all the springs if anyone wants a whole set. $60 +shipping
