STD Tuning Drivetrain 124 rear subframe upgrade
oel_brenner
04-19-2009, 10:37 PM #1
swapped in the entire rear subframe from a 1994 E420
this includes the larger 210mm diff housing
and the much beefier steel frame/mount
not to mention the brake upgrade
[Image: diff.sized.jpg]
[Image: diff2.sized.jpg]
[Image: diff3.sized.jpg]
so the subframe basically just bolts in, but this is the strange part..
the center support bearing in the M119 V8 cars is not located in the same position in the tunnel as the non V8 cars.. not sure why they did this but
I had to have a custom driveshaft rear section made longer the the E420 unit
[Image: driveshaft.sized.jpg]
so the stock 185mm diff had a 2.65 final drive ratio
the new E420 unit has a 2.24 gearset, and running the 18 inch wheels
my effective final drive ratio is an amazingly tall 2.17
now that the swap is complete, stop and go city driving is a bit sluggish, but as I drive this car mostly on the highway, its a great tradeoff.. highway RPMs are way down and I am pretty sure I will pick up some better fuel economy.
I think this will be even better with the planned 5-speed swap Big Grin
as my tachometer is currently not working and the speedo is horrifyingly inaccurate Exclamation , I cannot report RPM to speed numbers right now... stay tuned.
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
04-20-2009, 06:21 AM #2
LSD?
LSD?
oel_brenner
04-20-2009, 07:38 PM #3
nope...Sad
cars
trucks
boats
oel_brenner
nope...Sad
cars
trucks
boats
kamel
Naturally-aspirated SUCKS
176
04-21-2009, 12:37 AM #4
Hey, can you take me for a ride in your fail boat?
J/K 2.17's have to be nice on the freeway. Did you manage to get the speedo drive from the car you got this from?
kamel
oel_brenner
04-21-2009, 05:17 PM #5
(04-21-2009, 12:37 AM)kamel Hey, can you take me for a ride in your fail boat?
anytime you ( or any forum members ) are in the Tampa FL area
boat rides in the twin 617 vessel are available Big Grin Big Grin
[Image: jun_jul_2007_003.sized.jpg]
its still weird when I run the boat to hear the familiar klatta klatta of the 617...
thats a car noise! not a boat noise ! pretty cool though..
on the speedo... the E420 trans uses an electronic speedo, so with my final drive ratio way up, the cable speedo is horribly off.. I think I am going to put the gauge face from the E420 into my car
the 420 gauge face goes to 160 MPH
and mine only goes to 140 MPH..
right now the speedo is around 15 MPH too slow
switching the face to the 160 MPH unit it would only be around 5 MPH too fast
I love this final drive ratio on the highway... its sooooo smooth and quiet
still not enough data to decide if its a net gain or loss in overall fuel economy
( its sucks around town )
This post was last modified: 04-21-2009, 05:18 PM by oel_brenner.
cars
trucks
boats
oel_brenner
cars
trucks
boats
CID Vicious
09-25-2009, 07:42 PM #6
Damn, you had me going for a minute...I thought this was swapping the 124 rear into the 123. That would be sweet...
CID Vicious
04-27-2012, 07:56 PM #7
I miss the pics that were here.
