STD Tuning Drivetrain mercedes 240d 617 +4spd conversion
04-30-2009, 09:46 AM #1
i just picked up a 1980 240d for 500 turns out it was auto so i have a 4spd and shift linkage and a great 617 turbo with k 26 turbo but want to put both in my 240d auto i need to find a pedal set and flywheel do i need the cross member form that car as well?
http://www.youtube.com/watch?v=sqdexqX0bhM
thanks william
1980 240d auto
1980 300sd parts car
1958 219 ponton project car
This post was last modified: 04-30-2009, 09:47 AM by willbhere4u.
thanks william
1980 240d auto
04-30-2009, 02:33 PM #2
You have the right xmember with from the auto 240d. The DS will need shortening.
kamel
Naturally-aspirated SUCKS
176
04-30-2009, 11:51 PM #3
I'm in the process of doing my 4spd 617 as we speak. Pictorial will be up shortly. Wink
kamel
05-04-2009, 08:19 PM #4
thanks that would be great!!! I'm dying to do this swap I went junkyarding this weekend but was unsuccessful in finding a good w123 parts car all I got was a back window I'll keep looking for a peddle set I think I found a fly wheel from a 1969 220d will that work on a 617turbo Huh
Section106
05-04-2009, 11:40 PM #5
Which 240D model years can be used to bolt onto a 617? I found a 76 240D manual. Will that work or should I try to find something from the 80s?
Section106
05-05-2009, 01:39 AM #6
Any 220D or 240D will work.
05-05-2009, 06:06 AM #7
A 300d automatic trans mount will also work on the 240. Dont know if the SD mount is the same, but if your reversed the plate, the bolt holes line up. I did mine as a temporary solution, and left it on for about 6 thousand miles without issue.
05-05-2009, 06:22 AM #8
It won't stay that way for long.
The 240D automatic crossmember is the same as the manual 300D.
05-11-2009, 12:51 PM #9
thanks for all of the help!!! the peddle set and clutch master are all I have left to find still! going to try a different yard next weekend
is the 220d flywheel different weight than a 240d? just curious
06-08-2009, 03:56 PM #10
so I found a peddle set and a trans with 32k miles what else do I need for the om 617 vrs om616? do I need a different radiator oil cooler? any thing else???? so far I have a shift assemble, peddle set, trans, master and slave cylinder and lines
06-08-2009, 04:17 PM #11
The shifter linkage and DS will have to be modified for fit. I would get the DS done first.
You also need a flywheel and clutch. I just happen to have a set for sale.
06-13-2009, 09:25 PM #12
I just bought a clutch kit and got a fly wheel from a 220d sorry. I'm pulling the 617 out of my w116 in the next couple of week ends hopefully ! I got the peddle set installed alreaty it fit nice.
 6 Guest(s)
 6 Guest(s)
