STD Tuning Drivetrain Floor switch contact position
SicNick
07-26-2011, 09:59 AM #1
Hey guys, would anybody be able to tell me which contact on a 88 260E trans I would power with a pedal to the metal switch? Im thinking about using a toggle to feed power to this circuit when I want the trans to use 1st gear.
1984 Mercedes 190D, A$$ Packed then totaled by ins. company.
However I was able to utilize it's heart to give life to...
1987 Suzuki Samurai, Powered by MB OM601 and 4 speed auto.
Converted by myself with homemade engine mounts and a custom intermediate shaft. Turbo charged with Mitsubishi Mighty Max Turbo and custom Intake plenum, exhaust manifold and top mount inter cooler.
SicNick
07-29-2011, 10:30 AM #2
A 260e doesnt start in first gear? That doesnt sound normal. I would imagine it would just be the existing kick down switch. Does the kick down switch not work?
SicNick
07-29-2011, 03:13 PM #3
Sorry, should have clarified, I'm wondering where the signal from the factory floor switch would be sent. I don't have a Mercedes car around my Mercedes drivetrain... See signature.
It may be a lost cause but I thought if I powered this circuit with a toggle it would lock me in first gear, for certain off road situations Smile
SicNick
07-29-2011, 03:32 PM #4
Oh a should be a roundish looking solenoid on the back of trans I think.
SicNick
07-29-2011, 05:17 PM #5
(07-29-2011, 03:32 PM)winmutt Oh a should be a roundish looking solenoid on the back of trans I think.
Sweet, I think I've seen that, if I remember correctly it looks like a little black bellows and it points straight rearward with a single black wire exiting it?
SicNick
08-01-2011, 01:28 PM #6
That sounds right.
That sounds right.
Syncro_G
0-60 in 29 sec
280
08-02-2011, 12:21 AM #7
(07-26-2011, 09:59 AM)SicNick Hey guys, would anybody be able to tell me which contact on a 88 260E trans I would power with a pedal to the metal switch? Im thinking about using a toggle to feed power to this circuit when I want the trans to use 1st gear.
I think what you're after is a shift lever with the "B" position. Like this:
P
R
N
D
S
L->B
I think these are usually found on 300SD's
The "B" position is the same shift rod position as "L" but with a switch closed.
Wire that into the kick down switch harness.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
P
R
N
D
S
L->B
'75 240D 4-Speed
 7 Guest(s)
 7 Guest(s)
