STD Tuning Engine 606 IP
606 IP
606 IP
MB TECH
05-07-2009, 02:45 PM #1
Without doing any research I thought I would throw this out there, is it possible to run a 606 IP on a 617 motor? If so is it worth it?
Ya nevermind, I had a brainfart, 606 pump is a 6cyl. Anyone out there need a pump for a 606?
This post was last modified: 05-07-2009, 03:14 PM by MB TECH.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
05-07-2009, 03:22 PM #2
No. 606 is 6 cylinders, 617 is 5.
MB TECH
05-07-2009, 03:32 PM #3
ya I realized that about 5 seconds after hitting post (the lower part of my message)
1960 220SE
MB TECH
1960 220SE
05-07-2009, 04:17 PM #4
(05-07-2009, 03:32 PM)MB TECH ya I realized that about 5 seconds after hitting post (the lower part of my message)
Ah, I see. Wink If the pump is from a turbo engine it should have 6mm plungers that 617 users with an m-pump can rebuild theirs with.
This post was last modified: 05-07-2009, 04:18 PM by ForcedInduction.
MB TECH
05-07-2009, 04:30 PM #5
It is out of a turbo motor, so your saying I can transfer the plungers into my IP on my 617
1960 220SE
MB TECH
1960 220SE
05-07-2009, 07:19 PM #6
If it has the M-pump from a non-turbo euro engine, yes. If it has the MW-pump US models came with, no.
This post was last modified: 05-07-2009, 07:19 PM by ForcedInduction.
oel_brenner
05-07-2009, 07:26 PM #7
(05-07-2009, 02:45 PM)MB TECH Ya nevermind, I had a brainfart, 606 pump is a 6cyl. Anyone out there need a pump for a 606?
does it work ?
came out of turbo 606 or NA ?
how much you want for it ?
I might want it to put it on the shelf for some future CANbus experimenting
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
does it work ?
cars
trucks
boats
MB TECH
05-08-2009, 07:23 AM #8
It does not supply fuel on cyl. 3, could be something simple not sure though. One of my co workers was cleaning out his toolbox and he gave it to me (told me the car had a miss on cyl 3) other than that it is in good shape. Not really sure what its worth or what I might do with it. Let me know what you think it is worth and we can go from there.
1960 220SE
MB TECH
1960 220SE
05-27-2009, 05:35 PM #9
Do you still have the pump? I'd like to buy it.
