STD Tuning Engine Coolant pipe with euro manifold 603
08-14-2011, 07:33 AM #1
Anyone have a fix for this? Is there a 606 part or 126/140 pipe that works?
08-14-2011, 07:47 AM #2
The 126 pipe won't work very well.There was a thread on PP a while back that didn't seem to yield much... here.
This post was last modified: 08-14-2011, 07:51 AM by aaa.
iheartboost
08-14-2011, 11:10 AM #3
ive always been a fan of flexible lines. so maybe thats an option for you?
i know when i get on my way for the power aspect of my car there will be no custom bent oil or coolant lines. ill just use braided or something similar.
This post was last modified: 08-14-2011, 11:11 AM by iheartboost.
00 Mustang gt drift car
iheartboost
08-14-2011, 02:37 PM #4
(08-14-2011, 07:47 AM)aaa The 126 pipe won't work very well.There was a thread on PP a while back that didn't seem to yield much... here.
I'll talk to rusty and see if he can send me some EPC pics...
jonbobshinigin
08-16-2011, 09:54 AM #5
I believe that there is a pipe off of an om602 that you actually need. I will see if I can find out the information I likely stored somewhere and forget I did it.
1987 300TDT - 260,000 Miles
jonbobshinigin
300D50
Graphite Moderator, ala RBMK
08-16-2011, 11:06 AM #6
Is it something you could make out of a strip of hobby-shop brass/aluminum sheet, some pipe fittings, and time?
300D50
08-16-2011, 01:11 PM #7
Its the 602 tube. The problem is the bracket keeps the tube compression fitted into the tstat housing. There is a oring on the end to keep it from leaking. Im sure I can find a 602 tube somewhere. If by some miracle I have everything else done by this weekend I'll consider just using what I have and clamping it off until I can get the right part.
