STD Tuning Engine Engine braking
Engine braking
Engine braking
Imaginos
In disguise
66
08-14-2011, 01:27 PM #1
I've been trying to find an answer whether the Bosch IP pumps fuel when one uses engine braking?
Imaginos
Syncro_G
0-60 in 29 sec
280
08-14-2011, 02:00 PM #2
(08-14-2011, 01:27 PM)Imaginos I've been trying to find an answer whether the Bosch IP pumps fuel when one uses engine braking?
It pumps fuel at idle. Engine braking is pretty much the same as idle to the IP
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
Imaginos
In disguise
66
08-14-2011, 02:24 PM #3
Thank you, that's what I suspected.
Imaginos
dieselboy
Rotatin 5500 times a minute
680
08-14-2011, 03:17 PM #4
I don't think they do. I think the rack is being pulled back to the minimal fueling to try to bring it back to idle. If it is fueling it's a very small amount.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
E300TSC
Turbo-Supercharged
321
08-14-2011, 10:23 PM #5
The electronic pumps shut off completely when coasting or braking.
E300TSC
Imaginos
In disguise
66
08-15-2011, 05:25 AM #6
(08-14-2011, 10:23 PM)E300TSC The electronic pumps shut off completely when coasting or braking.
Yea, every car with an elctronic pump or an ECU does that.
I was wondering whether mechanical pump had some sort of detection so that governor cuts off fuel supply.
This post was last modified: 08-15-2011, 05:26 AM by Imaginos.
Imaginos
Syncro_G
0-60 in 29 sec
280
08-15-2011, 10:39 PM #7
Interesting. So i take it fuel cuts off when RPM is above idle.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
