M-pump oil supply
M-pump oil supply
The MW has the black hose running from the timing sprocket shaft bearing supply to the left side of the pump. Where does the oil go into the M-pump?
Ah, I see, the shaft is hollow.
So when mounting the M-Pump I only need to block the MW's oil supply port with a normal metric bolt?
(05-11-2009, 06:42 AM)ForcedInduction Ah, I see, the shaft is hollow.
I came across this while browsing a French 409D service manual.
