STD Tuning Drivetrain w123 manual transmission question
TheDon
606 Power!!
247
08-12-2011, 09:36 PM #1
Got my spare 4 speed for my 240D to swap in. The only difference is the reverse shift lever is upside down compared to mine.
[Image: f42abaa7.jpg]
[Image: 096a18a0.jpg]
See the bottom arm. Can they be removed and flipped or will that not work? I couldn't find the shifter rods that were supposed to go with the transmission.
I'm replacing my current transmission because 1st gear is not working at all.
I need to double check. I have an '82 and loping at the sticky on the manuals the curtsy transmission in my car is the aluminum body 4 speed.
Nevermind. I just went out and looked. Shift levers are oriented the same. The only difference is the last 4 or 5 digits of the transmission number.
This post was last modified: 08-12-2011, 10:17 PM by TheDon.
TheDon
08-18-2011, 07:14 AM #2
IIRC there is a allen bolt in that hole in the arm, can you confirm?
08-23-2011, 02:34 PM #3
(08-18-2011, 07:14 AM)winmutt IIRC there is a allen bolt in that hole in the arm, can you confirm?
Its a 6mm allen
Its a 6mm allen
