Where can I get H-Profile rods for the OM606
Hi,
I`m looking for upgrade my stock N/A rods, and some H-profile would be it
Does anybody know where to get them?
Best regards
Hi. Sten Parner on Sweden. Not over than 6000rpm
(10-07-2011, 08:59 AM)jeemu Hi. Sten Parner on Sweden. Not over than 6000rpm
Why the 6000 RPM limit with the H beams? I thought they were good for 7000+ ???
(10-07-2011, 09:16 PM)E300TSC Why the 6000 RPM limit with the H beams? I thought they were good for 7000+ ???26mm N/A piston pin and fat ass piston + high rpm is problems.
(10-08-2011, 01:13 PM)jeemu(10-07-2011, 09:16 PM)E300TSC Why the 6000 RPM limit with the H beams? I thought they were good for 7000+ ???26mm N/A piston pin and fat ass piston + high rpm is problems.
Also those Parner rods have little material on upper "eye". Made same plank as gasoline rods
(10-09-2011, 06:08 AM)EDH_PerformanceNot big difference on piston weight. Turbo have 28mm pin and it has 13mm inner hole, so its pretty stiff .(10-08-2011, 01:13 PM)jeemu(10-07-2011, 09:16 PM)E300TSC Why the 6000 RPM limit with the H beams? I thought they were good for 7000+ ???26mm N/A piston pin and fat ass piston + high rpm is problems.
I thought the N\A piston was lighter than the turbo piston? How thick is the wrist pin on the turbo piston?
What will be the best combination rod\piston if you will go up to 7000+rpm?
I know the head+++ must be modificated
