STD Tuning Engine Best drop in turbo for the 617 with modified IP
MTUPower
288
10-23-2011, 05:13 PM #1
What turbo is "best" for a 617-95X that is drop in- IE same T3 inlet and can be used as a daily driver on a car that has modified it's IP in some form? This basically rules out any VNT/VGT.
MTUPower
10-23-2011, 05:18 PM #2
Have you looked at the 603 turbos? I wonder what the map on something like a 350SDL turbo is like. What're you bumping against with your current turbo anyhow?
MTUPower
288
10-23-2011, 06:42 PM #3
(10-23-2011, 05:18 PM)aaa Have you looked at the 603 turbos? I wonder what the map on something like a 350SDL turbo is like. What're you bumping against with your current turbo anyhow?
A myna pump with an IC is worthy of a "better" turbo than stock.
MTUPower
10-23-2011, 07:08 PM #4
T3/T4 hybrid?
T3/T4 hybrid?
10-23-2011, 08:00 PM #5
(10-23-2011, 06:42 PM)MTUPower
Truthfully, I think your SAAB intercooler is a restriction and causing your smoking problem. You might get a better results without it and going back to a stock direct setup. But I do think a bigger turbo without with a different IC would be better.
Here are some I think may work, although some may disagree.
GT35 Ball bearing turbo, this may be close on the surge line but I think it's OK.
EDIT: Looking at the maps. These maybe to too big even for the Myna pump. I estimate it puts it past the surge lines. But you won't actually know it until you try it. Smile
http://www.ebay.com/itm/Garrett-GT3582R-...6061wt_753
http://www.ebay.com/itm/SUPER-70-HYBRID-...3826wt_911
This post was last modified: 10-24-2011, 06:10 PM by DeliveryValve.
10-23-2011, 08:19 PM #6
Is an hx30 too small for the om617?
10-23-2011, 08:20 PM #7
These are probably a better fit if it's a T3 setup - GT30R. Again with ball bearings... Which I am a fan of it for quicker spooling in lue of a VNT.
http://www.ebay.com/itm/Garrett-GT-Serie..._500wt_949
http://www.ebay.com/itm/Garrett-GT3076R-...4799wt_698
(10-23-2011, 08:19 PM)MFSuper90 Is an hx30 too small for the om617?
HX30 is in a good range for the 617.
This post was last modified: 10-24-2011, 12:22 PM by DeliveryValve.
10-23-2011, 08:33 PM #8
Awesome. Now the harder part is finding one i can afford Big Grin
led-panzer
10-24-2011, 05:29 PM #9
If your going to spend Garrett money, those master power R series turbos looked pretty damn good. First one in the compressor map link looks great for a 617
This post was last modified: 10-24-2011, 05:50 PM by led-panzer.
1985 300D 280,000 miles RIP
led-panzer
10-24-2011, 06:01 PM #10
(10-24-2011, 05:29 PM)led-panzer If your going to spend Garrett money, those master power R series turbos looked pretty damn good. First one in the compressor map link looks great for a 617
Yes I seen that. It does sound intriguing when your at that type of money. I like to see the maps of the R474, R494 and R544/545.
MTUPower
288
10-24-2011, 08:04 PM #11
(10-23-2011, 08:00 PM)DeliveryValve Truthfully, I think your SAAB intercooler is a restriction and causing your smoking problem. You might get a better results without it and going back to a stock direct setup. But I do think a bigger turbo without with a different IC would be better.
I have no smoke issues now that the timing is set to 19 degrees. There is less power, but nearly zero smoke. That tells me I need to move the timing closer to the 24 little by little and the magic number would be different for each turbo I believe. Remember I'm looking for a daily driver turbo- these "R" s units look good. For that money I might have someone build me a VGT setup as I do not have the time to design. build and install one.
This post was last modified: 10-24-2011, 08:05 PM by MTUPower.
MTUPower
dieselmeken
10-27-2011, 03:50 AM #12
To the 617 engine that my friend has in his Land Rover, a brand new Garret GTX2867R is ordered. It´s not on the market yet, a new product that is pressuretested up to 2,5 bar. We calculate 2,2 bar for app 250 hp.
The pump is for the moment 6 mm, 90cc, if it dont is enough I build a new pump.
I come back when we have installet the beast.
dieselmeken
10-28-2011, 12:06 AM #13
The beast is right! I wanna see!
kmaser
Turbocharged G-Wagen
125
11-12-2011, 05:13 PM #14
I'm finishing up the rebuild of my 617a and it will soon find it's way back into my gwagen, I haven't run it yet but I have my MW pump with Tomnik's 6.5mm elements installed. The plan is to run a VGT/VNT at some point but for now I am looking for a conventional turbo to run. The G wagen has 6.17 : 1 gears and 37" tires so I am more focused on bottom end than top end as it revs out quickly anyway, that being said I need a turbo that won't turn into a heat pump at the top end. The GT30R as suggested here looks promising but what configuration and AR should I be looking for ( T3 inlet, AR ? , internal waste gate ? , exhaust outlet V-band etc..? ) It looks like the cosworth housing might work well T3 inlet and the outlet looks close to the 3 bolt outlet on my stock K26 but no internal waste gate ?
looking for some input
thanks
This post was last modified: 11-12-2011, 05:16 PM by kmaser.
kmaser
thanks
11-13-2011, 12:41 PM #15
Someone else should chime in to be sure. But I really like the map on this GT3071R turbo for your application.
http://www.ebay.com/itm/Garrett-GT3071R-...458wt_1071
Garrett GT3071R (HKS GT2835) TURBO 4 BOLT GT T31 AR.63
Ideally for faster spolling for lower RPMs, you'll need to have the turbine a/r .63 or lower. Some of these vendors that sell GT30R' with a .48 a/r like the one I posted earlier would be great for you, but at the higher end, it will choke. That particular turbo is a GT3076R, which would not spool faster then the GT3071R, has an advantage of having a anti-surge housing for running higher boost. In any case I still like the GT3071R for the pump you have. Now if the GT2871R can be had in a T3, (it is a T25 turbo) it might be a better lower RPM choice.
This post was last modified: 11-14-2011, 01:33 PM by DeliveryValve.
11-14-2011, 01:38 PM #16
(10-27-2011, 03:50 AM)dieselmeken To the 617 engine that my friend has in his Land Rover, a brand new Garret GTX2867R is ordered. It´s not on the market yet, a new product that is pressuretested up to 2,5 bar. We calculate 2,2 bar for app 250 hp.
I found the map on this GTX2867R .
and the smaller GTX2863R - Looks good for lower end.
This post was last modified: 11-14-2011, 01:44 PM by DeliveryValve.
antonmies
Go MPR
59
12-09-2011, 02:36 PM #17
(10-24-2011, 06:01 PM)DeliveryValve Yes I seen that. It does sound intriguing when your at that type of money. I like to see the maps of the R474, R494 and R544/545.
Here is one for R545 / R544
[Image: mp400s54x77mm.jpg]
Still waiting for the final versions for the R47x and R44xx
antonmies
 18 Guest(s)
 18 Guest(s)
