STD Tuning Engine CDI injectors
CDI injectors
CDI injectors
diesel2fast4u
11-30-2011, 05:58 PM #1
Anyone know if the newer piezo's from an OM642 (V6CDI) would mechanicly fit into an OM648 (6 inline)
I know it will not be plug & play but I need more fuel
thanks
Grand cherokee WK (OM642)
diesel2fast4u
thanks
majesty78
12-01-2011, 05:32 AM #2
Why not use AMG C30 CDI Injectors and pump?
majesty78
Volker407
naturally aspirated
157
12-01-2011, 10:35 AM #3
No, they don´t fit mechanicly, hydraulically or electrically
Gruß
Volker
Volker407
Gruß
Volker
whipplem104
12-01-2011, 10:35 AM #4
They would probably fit but the cdi module will not run them. Piezo and solenoid injectors drive really differently. You can get larger injectors from bosch directly. Bosch motorsports. You will have to find a dealer in your area. They are hard to deal with for sure. Mostly racing teams.
whipplem104
diesel2fast4u
12-01-2011, 12:09 PM #5
@ Majesty78, expensive, hard to find & still to small
@ Whipplem104 , I also think they fit, We are running a standalone computer that can handle piezo and they are very big & easy to find from crashed cars
diesel2fast4u
majesty78
12-01-2011, 12:39 PM #6
What power are you aiming for?
majesty78
diesel2fast4u
12-01-2011, 06:57 PM #7
(12-01-2011, 12:39 PM)majesty78 What power are you aiming for?
400HP
For this, I have a budget but not unlimited, so the bosch motorsport way is kind of a no go...
diesel2fast4u
400HP
majesty78
12-02-2011, 02:51 AM #8
Above mentioned C30CDI AMG injectors plus pump from E400CDI and rail pressure sensor is fine for 400hp....
You can get your current injectors rebuilt to the 7hole AMG nozzle tips and specs, should not be to costy...
majesty78
diesel2fast4u
12-02-2011, 05:13 AM #9
(12-02-2011, 02:51 AM)majesty78 Above mentioned C30CDI AMG injectors plus pump from E400CDI and rail pressure sensor is fine for 400hp....
Nozzles are around 300 for 6 but where to find the specs?
diesel2fast4u
whipplem104
12-02-2011, 09:11 AM #10
Just curious, which standalone system are you using? I have been looking at Bosch and a few of the others.
whipplem104
diesel2fast4u
12-02-2011, 12:55 PM #11
(12-02-2011, 09:11 AM)whipplem104 Just curious, which standalone system are you using? I have been looking at Bosch and a few of the others.
Pm me your email adress and I will send you the info.
It's a system that was develloped here in Belgium
Can control piezo, inductive and pump injectors, up to 3 turbo's ....
diesel2fast4u
 9 Guest(s)
 9 Guest(s)
